Old 03-09-2006, 01:21 AM   #1
Corellian Corvette
No pressure in upper radiator hose. Is this normal?
Still working on getting my "new" 1974 Chevy pickup up to snuff and trying to 'undo' all the cusomizing by the previous owners
One thing I've noticed is that the upper radiator hose never gets any pressure. This seems unusual in that every single other vintage car I own gets a stiff upper radiator hose when the engine is at operating temp.
Now, the car doesn't overheat as verified by 2 gauges, IR thermometer and my hand.
P.O. says there is a 195 deg. thermostat which also is verified by the above gauges.
There is no coolant in the oil, no oil in the coolant, and no water leaks that I can see. I ran the engine with the rad cap off just to make sure the system is purged of air and there are no bubbles that might indicate a leaky head gasket. I'm told that the water pump is new.
Is it normal for these trucks not to pressurize the system? Again, the engine doesn't appear to be overheating but the lack of pressure has me worried.
Thanks!
Corellian Corvette is offline   Reply With Quote
Old 03-09-2006, 01:24 AM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
Re: No pressure in upper radiator hose. Is this normal?
Mine has pressure, I believe. I'm 99% sure.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 03-09-2006, 03:39 AM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Does the upper hose get hot like it flowing coolant?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-09-2006, 04:17 AM   #4
ACES
Life is a gamble
ACES's Avatar
My 1970 is not pressurized. I didn't think that 74's were pressurized, Do you have a picture of the radiator?
Even if it was pressurized at one time, it could have been swapped out to a nonpressurized system.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 03-09-2006, 11:35 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
When the upper hose seems to never get pressure, then there is usually a problem. First, is the core full of water? Sometimes the air that is trapped, when you fill the readiator, is more than the makeup bottle can handle (if you have one). Second (you won't like this one) there may be a head gasket leak and it has pushed the water out and there is a lack of fluid in the radiator. This can be found by most radiator shops, most have a carbon monoxide tester to see if you are getting gases in your cooling system. By chance do you have the wrong radiator cap on the radiator? There are basically two kinds, one that vents and holds and then there is one that vents and allows water to be pulled back in from the overflow bottle. Last but not least, what pressure rating is the cap, it may be two low.
piecesparts is offline   Reply With Quote
Old 03-09-2006, 12:40 PM   #6
Corellian Corvette
OK all good questions.
1. Rad is full of fluid.
2. Yes upper hose gets hot and coolant is flowing - I ran the car with the rad cap off, and I could see when the thermostat opened to let all the hot water flow in.
3. I checked for typical head gasket leak (bubbling in the water) but the water is still. That doesn't rule out a head gasked leak as you say.
4. How do I tell a pressurized vs. non pressurized system? There is an overflow bottle, and the rad cap appears to be a standard AC Delco type unit from the 60's/70's.
Old 03-09-2006, 01:19 PM   #7
piecesparts
Just for safety's sake---Get a new rad cap..15 psi.
Old 03-09-2006, 05:32 PM   #8
kevinr1970
If you have the car running and can see the fluid cycling into the radiator from the hose I would thing your fine? The hose will be stiffer the newer it is, but you should be able to squeeze it when the engine is running wiht the cap on.
It not a high pressure system so-to-speak, but I would still be careful opening the cap when hot!!!
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-03-2015, 02:37 AM   #9
three80three
I'm having the same problem on my 84 c10 I was under the impression my water pump maybe bad but there's no water leaking anywhere not in the weep hole or any where else, I've already changed the thermostat a d the upper hose the fluids in the radiator are up. My temp gauge will shoot up to about 230 the drop to about 170 /185.
three80three is offline   Reply With Quote
Old 01-03-2015, 03:38 AM   #10
piecesparts
Think of it this way, IF you boil or heat water in a confined space, it will expand and create pressure. That is a law of physics. So the older systems did not have a collection/return system on them, they just pressed up to a point that they would hold pressure and not boil or they lifted the relief on the radiator cap.. The later systems had a radiator cap that relieved to a bottle and then had a small orifice that would allow water to return to the radiator when the system cooled and the coolant inside shrank back down. The upper hose should get firm or somewhat solid as the system presses up. If it is not pressing up, then something is letting pressure out and your water is going to boil at a lower temperature. If you want to, you can change the cap to a later style and add a return catch bottle to you truck.
Frank
Old 01-03-2015, 05:02 AM   #11
rich weyand
rich weyand's Avatar
'74 should have a coolant reservoir bottle. Does yours? Some people remove them to "clean up" the engine bay. I strongly recommend you use one. Google it; you can get NOS and repros on-line.
Chevy radiator caps are only good for so long, and I have had premature failures as well. Replace yours with a 15 PSI pressure cap.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 01-03-2015, 08:04 AM   #12
donut
donut's Avatar
Have you pressure tested the cooling system to verify you have no leaks? Why bump a 9 year old thread for your issue when you already have a thread going?
As far as the temp spiking, IMO, it's the nature of the beast. Thermostats don't "snap" open. They slowly open, allow warm coolant to flow out of the block, cool coolant is allowed to flow in. In the meantime, the running engine is still producing heat, allowing temp to spike briefly while thermostat is opening.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
