Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 03-09-2006, 07:27 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Q on polishing alluminum
I have a rather nice Snap On truck box mounted in the bed of my truck. This sucker is huge, and I love it. Been offered cash for it many times, but I refuse to sell it. However, it looks like ass.
So I removed it from the truck today, and started to scrub it with some super clean, then I hosed it down with some alluminum cleaner, which has taken it to virgin alluminum. I'll be removing the stickers from it, and then wet sand it with some 1000 grit or so wet/dry paper. I'll do the sides, but I think the top, the diamond plate will be fine without the sanding.
Once I do that, I'll hit it with the buffer.... this is where my questions come in.
Do I simply use automotive rubbing compound, or is that too coarse to start off with? Do I just go straight to polish? I have some mothers mag and wheel polish that has done wonders on small pieces, but I don't know if it would quite get the look I am going for here... I want it to look like new, like chrome...or at least, like polished alluminum should look.
After that... how do I keep it looking good? I don't want it to ever look this bad again. Do i simply keep it clean, and wax it like it was a painted piece...every 6 months or so?
Also, do I need to polish it and then put on the new Snap On stickers... or do I need to put the stickers on before the polish? I can't see them sticking to the polished surface very well, but I can see the polish damaging the stickers if I buff over them.
What to do.. what to do.
Old 03-09-2006, 08:03 PM   #2
MrGoodpliers
MrGoodpliers's Avatar
Re: Q on polishing alluminum
You will probably need to use rouge or some other hard polishing compound with moderately stiff buffing wheels to get the sanding scratches out. Then hit it with the cream type stuff to really make it shine.
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 03-09-2006, 08:07 PM   #3
rtsmith
Just a suggestion Wenol aluminum polishing products work great for what you want to achieve. I use it often to polish aluminum valve covers and intakes.
rtsmith is offline   Reply With Quote
Old 03-09-2006, 08:59 PM   #4
Ron 586
RIP Mr Ron
Ron 586's Avatar
I'm not sure if you can still buy this or not but I had good luck with DuPont red hand rubbing compound cut with a little water and a buffer. It might take 2 or 3 passes with that then jewelers rough to get the mirror look. I used it on tanks, steps, and even a tool box or two in my truck driving days. I tried all that high dollar stuff and never found anything better. Of course I went to my local DuPont dealer to check on paint for a project a year or so back and everything that I asked for is no longer available. I hate it when that happens.
Ron (Mr Round Tuit)
Be kinder than necessary, for everyone you meet is fighting some kind of battle
TN Message Forum
TN Facebook Group
SETN Truck Show
My Photobucket
Ron 586 is offline   Reply With Quote
Old 03-09-2006, 09:24 PM   #5
OhioChevy
Andy, after going over it with the 1000 grit you should step up to 1500-2000
grit paper. Go to Lowes and in their tool department they will have sticks
of polishing rouge. They will have about 6 or 7 different grits but you only
need to get the number 1-3-6. Use them in that order and you will have a
nice looking tool box. I would polish the box and than put the stickers on
if you plan on replacing them. Sounds like a lot of work...you bet it is... but
the end results will look great. I have seen some folks use tongue oil and
others spray with a clear to retain the shine. Can't say which is the best
though.
OhioChevy is offline   Reply With Quote
Old 03-09-2006, 10:03 PM   #6
Primered_69
Primered_69's Avatar
http://www.jalopyjournal.com/forum/s...ad.php?t=97179
this is about polishing aluminum that has some real good information and some other tips
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 03-09-2006, 10:10 PM   #7
Longhorn Man
sweet... keep the info coming if there is any more to know.
Is this polishing rouge very expensive?
Old 03-09-2006, 10:37 PM   #8
chipflyer
chipflyer's Avatar
I have one word for you, Flitz!
It's amazing stuff.
http://www.flitz.com/
By the way Andy, I got the glovebox lite today, THANKS!
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 03-09-2006, 10:41 PM   #9
ChevyCrazy67
ChevyCrazy67's Avatar
I used 00 steel wool pads on my top and sides where the scratches wasn't as bad then 1500 to 2000 grit paper where they was worse. the steel wool is a rough go but it sets up the buffing to be done later very nicely.
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 03-09-2006, 10:49 PM   #10
HotRod71
Short, Fleet, Slammed, V8 Club
Rouge should not be too bad. Jewlers rouge comes in different colors and that relates to the cutting ability of the rouge. IMO I would NOT sand it at all. The rouge will cut it and remove scratches by itself. Green rouge is what a place in Cali, Mag Masters. 1419 E Edinger Av. Santa Ana, CA 92701. 714-543-8088, uses to buff out bad looking billet aluminum wheels. But what Ohiochevy said would be the way I would go. Just my humble opinion.
71 Chevy SWB Fleetside (WIP)
www.4x4grace.com
HotRod71 is offline   Reply With Quote
Old 03-09-2006, 11:32 PM   #11
cdowns
cdowns's Avatar
i'd start with a big box of brillo or sos soap pads first then a large can of comet scouring powder and a sponge then go with a circular buffer and metal polish of your choice(i like mothers) make sure to have lots of terrycloth to whipe the polish with then drop off at the powdercoated for a nice clear finish// you could also go the "machine turned look" if you do don't waste money on the eastwood kit
Old 03-10-2006, 05:37 AM   #12
Mudder
Mudder's Avatar
This has a lot of good info in it that shouldn't be lost. I'm moving it to detailng and I will leave a direct here to it.
California Customs aluminum cleaner/polish
Mudder is offline   Reply With Quote
Old 03-10-2006, 08:29 AM   #13
Hey Andy,we`re neighbors!Welcome to Aluminum Polish Street,Detailville!!
Old 03-10-2006, 11:00 PM   #14
wibilly
wibilly's Avatar
andy before i did anything i would go to a boat shop that deals with alot of pontoon boats. i don't know what they use but i can tell you whatever it is it will save you alot of hard work.
common sense isn't so common anymore
wibilly is offline   Reply With Quote
