Old 03-19-2006, 07:31 PM   #1
Hobbs
Body lift problem
I am doing a performance accessories 2’’ body lift on my 88 suburban. There are 7 places on each side that the body is mounted to the chassis. Numbering them 1-7 starting at the engine, I have a big problem with 4,and 6
1-3 are straight forward. From the bottom you see the bolt head that can be unscrewed.
(I did not take it all the way off yet, but I assume it is screwed into threads in to the body)
4 and 6 are completely different from 1-3. The only thing visible is a flat “stopper” under the mounting block. Nothing to attach a wrench to. I thought maybe that I could find something by looking under the flooring from inside the cab. Thinking that the bolt was oriented facing the ground and that "stopper" was actually some type of nut. Nothing under the floor carpet.
Any advice as to how to approach these attachments?
If it comes to it, I could take pictures because I am stumped.
Thanks,
Hobbs
Hobbs is offline   Reply With Quote
Old 03-19-2006, 09:27 PM   #2
Southedisto
River life......
Southedisto's Avatar
Re: Body lift problem
IIRC the ones that you can not see are nut plates molded into the body. I had a problem with one, had to cut a hole in the interior and body to put vise grips on it. Dont sweat it unless the bolts can not be removed. Also, use some lube when screwing the new bolts in.
Southedisto is offline   Reply With Quote
Old 03-19-2006, 09:58 PM   #3
Hobbs
Please elaborate....
Do you mean that the one you did not have a problem with screwing off, you just unscrewed the nut plates? And looking ahead, if I have a blind insertion of the screw, how am I going to insert the new longer one?
i apologize if these questions are one of those things that will answer itself once I start unscrewing, but I am trying to anticipate problems before I have my help standing there.
Thanks for your response.
Hobbs
Old 03-19-2006, 10:16 PM   #4
Southedisto
River life......
Some nut plates are hidden, like behind the seats of trucks, and you cant see them to know what is happening. If you unscrew and unscrew and the bolt doesnt come out you need to investigate find the receptacle cut a hole and chisel, vise grip or weld something to remove the bolt. The nut plates are spot welded to the body, so they either break loose or the nut spins inside of the fixture. Either way, you will most likely have to cut a hole. The nuts are centered, for the most part with the plate around it.
Old 03-19-2006, 10:35 PM   #5
Hobbs
I really appreciate your explanation, but when I look up from underneath, the only thing I see is the nut plate. The nut plate up against the spacer between the chassis and the body. There is no screw, no hexigon nut. That is the problem. There is nothing to grab and spin. I can see what I would buy to be the nut plate, just can not see a screw.
I understand what you are saying, unscrewing from a nut plate can cause the plate to spin THEN, you have to grab it, maybe cuting the floor to get to it. But I can get to the nut plate, just not the screw.
Should I twist the nut screw?
Hobbs
Old 03-19-2006, 10:47 PM   #6
Southedisto
River life......
Any way to take a pic? If not give me spot and Ill go crawl under mine and look at it. I only have a truck, so hopefully someone with a burb may know something I am forgetting
Old 03-20-2006, 08:53 PM   #7
Hobbs
pic of the body attachment I was asking about.
Hobbs
did not work
Old 03-20-2006, 09:02 PM   #8
Hobbs
maybe now?
Old 03-20-2006, 09:05 PM   #9
Hobbs
Cool...Now you can see what I was talking about. This is a view from underneath looking at the 4th from the front body attachement. Nothing to unscrew and nothing visible from the inside under the carpet. Hope I do not have to dig these out through the floor.
Hobbs
Old 03-22-2006, 12:32 AM   #10
Bob Gervais
Truckless for the moment...
Bob Gervais's Avatar
The Burbs have two places, which happen to be #4 and #6 positions, which don't have bolts or nuts. The mount is nothing more than a spacer to help support the bed area. Once you get all of one side loosened and jack up the body, those two bushings just pop out. No hardware involved.
1987 V1500 GMC Suburban, 350 TBI, Flowtech dual exhaust, Rough Country 2" spring lift, 56" 3/4 ton rear spring conversion, 33" BFG All Terrains, and the smokescreen engine mod -- Former truck, searching for another now...
Bob Gervais is offline   Reply With Quote
Old 03-22-2006, 08:39 AM   #11
Hobbs
Many thanks Bob!
I thought as much, but the last thing I wanted to do was get in the middle of this project and get stuck.
Hobbs
Old 03-22-2006, 04:47 PM   #12
Bob Gervais
Originally Posted by Hobbs
Many thanks Bob!
Hobbs
I hear ya man. I replaced my body mounts last year, and thought I was missing more parts than I thought!
Old 03-29-2006, 09:24 PM   #13
Hobbs
Finished the pro accessory 2" body lift. Yea! I however learned that suspension/body lifts are like breast augmentations...you never go big enough.
I have found a Tough Country 2" suspension lift for a 2wd that I am looking into. Anybody have any experience with it? That would give me 4". I have some 33" BFG's I am going to add. At this point clearance is really not an issue, it is all about the look.
Old 03-29-2006, 09:26 PM   #14
Hobbs
by the way... from this pic does it seem like my rear end is sagging? I was thinking about those 0 rate add a leafs to prop up the rear that Bob turned me on to.
Hobbs
Old 03-29-2006, 10:10 PM   #15
Bob Gervais
Looks good!
Suburban and Blazer sag are sometimes an optical illusion. The wheelwell openings are at different heights, making it look saggy in the rear. The best way to tell would be to take a measurement to the bottom of the rocker panel on each end, and compare. I found that mine sagged at the rocker panels when I had the 2" lift leaf springs installed, so I added the zero rate and it evened things out at the rocker panel, but still looked saggy because of the wheelwells. You may want to think about just adding the zero rates, or 2" lift rear springs and see how it looks before you tackle the front.
Now that I've switched to the 56" 3/4 ton stock springs, my Burb sits nose high. Not a biggie, because I figured it would come out like that, but I do need to address it. I think what I'm going to do is a shackle flip kit from 4XDIY in the rear. That'll put it slightly nose down when unloaded, but even when loaded with all my junk.
Old 04-01-2006, 11:16 PM   #16
ALASKA ALUMINUM BEAR
ALASKA ALUMINUM BEAR's Avatar
ITS funny i found this post today--because i am doing the same exact body lift--and 4-6 had me stumped---but we got it figured out--now bob--to put nuts and blots back in--one has to drill through the inside bed--and attach a large washer--correct---how about bolt--or holder no 6--what do we do there--to attach a bolt...most people with burbs--do not put back in 4-6 --put i think that is stupid--the more stablity one can get--the better....i cannot figure six out---that is how to put a bolt and nut through....by the way hobs--did you drop your tank and rear bumper...we drop the tank and tow hitch--but i do not want to drop the reunel rear bumper--we also took out the raditor and the front vertical core support beam....what esle did you drop...bob please let me know how to get that 6 bolt in....also bob--thanks for the info on ri beaches---i'll be there this fall fishing for stripers....god i cannot wait....thanks guys
aab
john
ALASKA ALUMINUM BEAR is offline   Reply With Quote
Old 04-01-2006, 11:28 PM   #17
screwballl
Tonawanda 454
screwballl's Avatar
hmmm yours looks now liek mine does stock.. guess they had different heights in 91...
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 04-03-2006, 06:30 AM   #18
Bob Gervais
aab
john
I didn't put bolts in mine, but I think you are right, the more solid it is the better! I did all new bolts on the mounts that already had bolts, but I just stuck the spacers back in there like they were from the factory.
No problem on the info, let me know when you're headed this way!
Old 04-04-2006, 11:21 AM   #19
MASiefert
I'm with Screwball, yours looks like it sits lower or about the same as my 85 3/4 ton. I had to replace some of the leaves in my rear springs 2 years ago. It helped the sag tremendously.
Good Luck!
MAS
MASiefert is offline   Reply With Quote
Old 04-05-2006, 01:06 PM   #20
Hobbs
aab
john
To answer your questions to me....
1. I did not change anything with the tank or rear bumper. My rear bumper stayed put. That is the one thing about a body lift that looks a little off. You create a space bt. the raised body and the original bumper. As for the radiator I cut the bottom off the shroud to allow it to move with the body. Acutually did that without taking it out. Just a hack saw with my head stuck down into the engine.
2. I agree it would be nice to have 4 and 6 bolted on. I did not. I did put them back by inserting a bolt between the original and the added lift block. If only to keep the two together. But they are not attached to the body.
Good luck.
Hobbs
Hobbs
1988 sub. 3/4 ton 2wd 454.
BFG 295/75/16 on American Racing 16x8
