Old 04-02-2006, 09:27 PM   #1
Hobbs
1988 sub power door locks
Where do I start for troubleshooting powerdoor locks that do not work. I have checked the fuse chart. It says that the rear window is on the same fuse and it works.
Suggestions?
Hobbs
1988 sub. 3/4 ton 2wd 454.
BFG 295/75/16 on American Racing 16x8
Hobbs is offline   Reply With Quote
Old 04-04-2006, 01:54 AM   #2
89 crew
Re: 1988 sub power door locks
I would probably start at the drivers door switch. Check for power. If you don't have it there the problem will be between the door and the fuse panel. If you have power going in trip the switch and see if it is going out. You could have several bad switches. (had that on a caprice) Hope that helps
89 crew is offline   Reply With Quote
Old 04-04-2006, 08:09 AM   #3
Hobbs
Thats what I thought. Just never messed with a power lock problem. Sometimes things can have an easy, most often, "duh" kind of solution I wanted to make sure I was not overlooking before I dove into the door.
To add, non of the power door locks work. Do all the locks come off of the driver side? Or does this indicate that the problem may be more central?
Thanks,
Hobbs.
Hobbs
Old 04-18-2006, 12:58 AM   #4
Bill W
All the locks will unlock from the drivers door and the passenger door.
Bill W is offline   Reply With Quote
