Old 04-06-2006, 07:11 AM   #1
`86 Hydro-boost On`67?
I have an`86 3/4t 2wd Diesel Suburban I want to take the hydro-boost off of.I`m building a`67GMC pro street that will have a knobby bumpstick to say the least(low vacuum/hi-power).I want to use the complete system from Master cylinder to steering box.What`s there to the swap?The truck is not begun.Would it be any advantage to use a`73-up front-end assembly?What is necessary to install the later syeering gear and M/C?
Old 04-06-2006, 08:50 AM   #2
smokekiki
Mike
smokekiki's Avatar
Re: `86 Hydro-boost On`67?
Here is a thread I saved on hydro boost.....http://67-72chevytrucks.com/vboard/s...d.php?t=175714
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 04-06-2006, 10:24 AM   #3
Thanks,Smoke.That helps alot.
Old 04-06-2006, 01:42 PM   #4
70GMCer
70GMCer's Avatar
I'm thinking on doing the same......
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-06-2006, 01:46 PM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here is a link to a swap of an 1989's hydroboost on to my 1969. Hope this info helps.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
