Old 07-28-2002, 12:25 AM   #1
paintpyro
paintpyro's Avatar
spacing issues?
I got issues. I finally started putting on my new rear coils. Got the first one done, but the second wheel, I couldnt get off. It seems like the center hole of my rally wheel was wedged against the center of the hub, and I can't shake it loose. Is this making sense? Any suggestions?
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 07-28-2002, 12:34 AM   #2
bigvinnie
bigvinnie's Avatar
makes sense but I can't picture how the wheel could get stuck to the hub, but if you can start hitting the tire from the inside with a small sledge hammer while turning the tire it should break loose...
also try wobbling the tire back n forth... you could also hammer on the wheel from the inside, using a block of wood between it and the hammer to avoid damage...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 07-28-2002, 12:42 AM   #3
Low68
Low68's Avatar
I had the same problem a while back. I just took a hammer and was wacking on the tire from the back and wobbled like bigvinne said and it eventually came loose. It took a while but it came off. I tried grinding down part of the axle but it didn't help. good luck.
Build Thread
Low68 is offline   Reply With Quote
Old 07-28-2002, 01:36 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It may not be the fitment, but just the fact that it has been on for so long(if that is the case). We see this all the time at my work, we just crawl under with the BFH and have at it while someone is spinning it.
