Old 04-20-2006, 06:04 AM   #1
EROC
Active Member
FS 3/8 Temperature Sensors
I made these mostly for myself and just to see if it would work. I am not a professional machinist, but I think they came out well. I can make some of these and ship them out if anyone is interested. They're just GP Sorensen sensors from Advanced Auto that I cut down from 1/2" to 3/8" pipe thread. Should work for temperature gauges in all 67-72 trucks with original gauges. $25 shipped in the lower 48. Thanks, Eric
69 GMC 2500 Camper Special
88 S10 Pickup
04 Impala
I ship UPS from 24153
EROC is offline   Reply With Quote
Old 04-20-2006, 10:02 AM   #2
pjmoreland
pjmoreland's Avatar
Re: FS 3/8 Temperature Sensors
I'd like one please. Do you take PayPal? Thanks!
pjmoreland is offline   Reply With Quote
Old 04-20-2006, 02:49 PM   #3
EROC
Active Member
Yes I take Paypal. PMed you. Thanks, Eric
88 S10 Pickup
04 Impala
Old 04-21-2006, 09:57 PM   #4
Green Machine
Green Machine's Avatar
Eroc - I'll take one too - PM sent.
Just a note to others reading this if your're doing a newer engine swap you may need this since they may be no place screw in the normal sized 1/2 npt sender.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-22-2006, 03:42 AM   #5
greenhorn male
greenhorn male's Avatar
Does anyone know where I could get the wire connector that fits the tip of the sending unit. Mine rotted away.
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
Old 04-22-2006, 01:51 PM   #6
454_72_4X4
454_72_4X4's Avatar
I have Trick Flow aluminum heads and they have the 3/8 npt holes also. Those senders would be handy if you're using the stock gauges, (I use mechanical Autometer).
Good idea EROC!
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-22-2006, 11:12 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Try Ron Francis www.wire-works.com
I use a spade terminal and bend things a little so it won't come off.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-23-2006, 01:15 AM   #8
greenhorn male
Thanks Fred. Maybe I'll try a spade connector. It'll look a lot better than my alligator clips
03 Tahoe
Old 04-23-2006, 01:35 AM   #9
pjmoreland
pjmoreland's Avatar
I bought one from Ron Francis recently. Here's the link to their online catalog. Scroll about half way down. It's part number TS-10, and you need a BM-8 terminal as well.
http://www.ronfrancis.com/wiringaids.php
Old 04-24-2006, 09:09 AM   #10
Old Yeller 1970
DON'T TREAD ON ME
Old Yeller 1970's Avatar
EROC I may need one of those. I bought a 3/8 sender from autozone but I'm not convinced it's the correct Ohms to read the temp correctly. I'm getting ready to put in a new radiator and figured I'd Ohm my current sender. Does anyone know what the Ohms are on the original sender?
Old Yeller
Old Yeller 1970 is offline   Reply With Quote
Old 04-24-2006, 11:12 AM   #11
pjmoreland
pjmoreland's Avatar
It should be about 1000 Ohms when cold.
Old 04-24-2006, 10:59 PM   #12
Green Machine
I found this cached link on google back to board, not sure if it exists anywhere else - has some ohm test reading and other good info -
or search for ts6641
http://72.14.203.104/search?q=cache:...s&ct=clnk&cd=1
Old 04-24-2006, 11:11 PM   #13
Old Yeller 1970
DON'T TREAD ON ME
Thanks to both of you for the info. My gut instinct is telling me the sending unit I have ain't right. I sure would hate to ever burn up the engine you see in the sig just because of some kind of coolant failure. It may be a few days before I have a chance to get to it and let everyone know.
Old Yeller
Old 05-17-2006, 03:59 PM   #14
Old Yeller 1970
DON'T TREAD ON ME
I finally got around to checking my sender today and it is definitely not the correct ohms. At room temp it measured 2200 ohms and in a boiling pot of water it was 174. According to pj it should have been 1000 at room temp but in the thread Green Machine posted these were the specs given.
Temp..........Factory (Ohms)
70..............490
180.............130
200.............110
Either way mine won't work. So, EROC if you still have the correct sender I need one for sure. However, I'm completely broke at the moment so it will be a few days before I can even afford $25 but I will definitely take one when I have the dough.
Old Yeller
Old 05-24-2006, 01:03 PM   #15
drink2mny
drink2mny's Avatar
Usually hate to bring old threads up..
But we are putting a '96 vortec 350 in a blazer at the shop and need a sending unit for it. so it will work with the early style gauge.
You still have some??
Support The Board
drink2mny is offline   Reply With Quote
Old 05-25-2006, 11:52 AM   #16
drink2mny
drink2mny's Avatar
ya there EROC??
Support The Board
Old 05-25-2006, 12:07 PM   #17
EROC
Active Member
I can make a few more. PM sent.
88 S10 Pickup
04 Impala
Old 05-25-2006, 12:12 PM   #18
drink2mny
drink2mny's Avatar
back at ya..
Support The Board
Old 04-06-2007, 07:42 PM   #19
67stepside
67stepside's Avatar
I PM'd you. I am interested in one of these. Thanks
67stepside is offline   Reply With Quote
Old 01-30-2013, 11:55 PM   #20
cwsohm
cwsohm's Avatar
If you still have any of the 3/8 NPT temperature sending units, I would love to buy one. New to the forum so not sure how to PM you, but will try to figure it out.
cwsohm is offline   Reply With Quote
Old 01-31-2013, 06:23 AM   #21
nobolt
nobolt's Avatar
**** original poster not active since 2010 ****
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 02-05-2013, 04:53 PM   #22
HuggerCST
HuggerCST's Avatar
I'm interested in one too if anyone knows where to get one.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 02-05-2013, 07:01 PM   #23
asolde
asolde's Avatar
I just had one made. I bought the sensor at advance auto parts, then took it into work to our machine shop and had them do a G job for me. Any machine shop should be able to do this for you. Not sure what they would charge though. And I am not sure how accurate the sensor will be now?
asolde is offline   Reply With Quote
Old 02-05-2013, 11:40 PM   #24
HuggerCST
HuggerCST's Avatar
That's what we are thinking about doing, but as common as the need for this is, it seems like someone would be selling them.
Wynne
Build thread
53 Chevy shortbed
69 Camaro
