Old 07-28-2002, 04:19 PM   #1
1972GMC
starter problems
15
I have a 1972 GMC 1500 custom. I have replaced the starter on it about 15 times in a year. The problem isnt the fly wheel, I just put a new one on. The problem is that when you put the starter on it doesnt line up with the fly wheel right. I shim it to fit perfectly, but a week later it is grinding on the fly wheel. if anyone can tell me what to do to fix this I would appricate it.
1972GMC is offline   Reply With Quote
Old 07-28-2002, 04:31 PM   #2
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Are you sure you have the right flywheel, starter, and if it is shimmed properly then there shouldn't be a problem, Some of the shim kits have a little rod to guage the distance between the flywheel and the starter, You could possibly have the wrong number of teeth on the flywheel also other than that I don't really know what it could be.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 07-28-2002, 04:37 PM   #3
1972GMC
yea the fly wheel is right and the starter too. About a year and a half ago i got everything working correctly, but one of my starter bolts broke and when i went to start the truck it chiped the teeth on the starter, and ever since then i have had problems. i guess the only thing to do is put a new fly wheel and starter on it and cross my fingers.
Old 07-28-2002, 04:39 PM   #4
lukecp
Formerly yellow72custom
lukecp's Avatar
Sounds like your starter may be twisting itself under the load of cranking your motor. To fix this, go to a Chevy dealership parts depratment, and ask for a starter brace. It is a small piece of bent angle iron that goes from the front of the starter to a hole that is drilled and tapped in the block of your motor. It will cost around $5, and it will keep the starter from moving when it cranks. Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-28-2002, 04:44 PM   #5
Firefighter
Yep, I would say that is your problem with the starter and flywheel replace both of them and that should fix the problem!!!
Yellville, Ar. USA
