Old 04-19-2002, 04:14 PM   #1
TC70C10
TC70C10's Avatar
Post Longhorn 160 degree question
Longhorn, Do you can any heat blowing in the winter or do you swap thermostats in the fall?
1970 Chevy C-10 350,3 spd
1998 Pontiac Firebird
1999 GMC Envoy
Harvest,AL 35749
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 04-19-2002, 04:17 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
I do have to swap, that is the only bummer on the 160 degree. However, it is only 5 min of trouble.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-19-2002, 04:23 PM   #3
Baradium
Binder Rep
Baradium's Avatar
Post
why do you run a 160 degree at all in the first place?
Baradium is offline   Reply With Quote
Old 04-19-2002, 04:26 PM   #4
TC70C10
TC70C10's Avatar
Post
I would think the 160 would be like running no thermostat at all.
1999 GMC Envoy
Harvest,AL 35749
Harvest, AL 35749
Old 04-19-2002, 04:28 PM   #5
Longhorn Man
Post
no, with no thermostat, the motor is able to overheat, with a 160, it stays at 165 to 175...no higher at any given time. Towing in Tx, or sitting at a train crossing...
It reduces vapor lock, gives better gas mileage, and makes more power. Also, it lowers oil temps, which is great in it's self.
Old 04-19-2002, 04:29 PM   #6
Baradium
Binder Rep
Baradium's Avatar
Post
and the only reason people do that is when they don't have a cooling system that is up to thier motor and climate.
Old 04-19-2002, 04:32 PM   #7
Baradium
Binder Rep
Baradium's Avatar
Post
you should be able to get higher milage with the higher temps if it's set up right. Vapor lock sends a signal though, seems your fuel line routing is in need of a revamp.
Old 04-19-2002, 07:09 PM   #8
Longhorn Man
Post
My cooling system is spot on. Put a 190 in it, and it might get to 210.
If you make more power without introuducing more fuel, you should get better MPG if you sty 'out of it'. A cooler engine will introduce a cooler intake charge, which makes more power. Dynos prove lower temps = higher h/p. Why you think the performace chip companies recomend a 160 thermostat?
Old 04-19-2002, 07:26 PM   #9
71Chev
71Chev's Avatar
Post
I switch mine. 160 summer, 180 winter. The 160 will still provide enough heat in the cab in 30-40 degree temps.
  • 71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 04-19-2002, 07:34 PM   #10
69 longhorn
Post
I have also used a 160 in the heat of the summer. With the aluminum heads,the longhorn does fine on a 180 stat,(175 on the road,& 185 in town). the aluminum tosses a lot more heat off........69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-19-2002, 07:36 PM   #11
busterwivell
Post
I'm goin' to try a 160 now to see what it does in my 402. With a 180, I run about 190-195. It's worth a shot. Thanks for sharing.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 04-19-2002, 07:41 PM   #12
Longhorn Man
Post
No problem.
Even if I 'm full of ca-ca, you'll only be out a few bucks. I think I got mine at auto zone...it's been a couple years.
