Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 04-21-2006, 10:45 PM   #1
oscareltemblo
oscareltemblo's Avatar
Aluminum cleaner??
I need an aluminum liquid cleaner to clean up the 6.0 that I bought any suggestions?
My Official build thread http://67-72chevytrucks.com/vboard/s...d.php?t=196844
oscareltemblo is offline   Reply With Quote
Old 04-21-2006, 10:57 PM   #2
68 short step
Re: Aluminum cleaner??
oven cleaner
68 short step is offline   Reply With Quote
Old 04-21-2006, 11:03 PM   #3
oscareltemblo
I bought some oven cleaner in the dollar store so that will take care of it thanks.
Old 04-22-2006, 12:59 AM   #4
Green Machine
Green Machine's Avatar
DO NOT use oven cleaner on aluminum, you'll be very very sorry, read the can label !!!
What are you trying to get off, light grease ??? Mix up some dish soap or Simple Green 50/50 with water and spray it on, let it soak for a whaile and hit with a power washer or car wash.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-22-2006, 02:08 AM   #5
oscareltemblo
My friend told me touse Aluma Brite has any one used it before?
Old 04-22-2006, 06:04 AM   #6
Mudder
Mudder's Avatar
What are you cleaning?
Lots of cleaners and chemicals will etch aluminum.
Mudder is offline   Reply With Quote
Old 04-22-2006, 06:48 AM   #7
70GMCer
70GMCer's Avatar
NO OVEN CLEANER!!!! I always use "Simple Green" or "Castrol Super Clean" on aluminum. Oven cleaner can turn the aluminum black and can etch it bad....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-22-2006, 11:48 AM   #8
greasemonkey
greasemonkey's Avatar
Castrol Super Clean can also etch aluminum, I found out the hard way.
How about regular engine cleaner? I have had good luck with Foamy Engine Brite, I think it is safe for aluminum.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 04-22-2006, 12:11 PM   #9
70c10
67-72 Addict!
70c10's Avatar
I also like the Foamy engine brite for engines!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-22-2006, 12:21 PM   #10
rigon4
rigon4's Avatar
if you live near a truck stop they will have aluminum acid takes every thing off
rigon4 is offline   Reply With Quote
Old 04-22-2006, 12:28 PM   #11
jakeslim
Premium Level Member
jakeslim's Avatar
Mequires aluminum cleaner works great.
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 04-22-2006, 02:51 PM   #12
68 short step
i use oven cleaner on all my stuff.... never had any problem with it.......need pics of how it cleans up
http://www.ls1tech.com/forums/showth...7&page=1&pp=20
never had any problems with it. been doing this for over 6 yrs now too.
Old 04-22-2006, 03:42 PM   #13
cdowns
cdowns's Avatar
water will work just fine if it's run thru a pressure washer
Old 04-22-2006, 05:16 PM   #14
70short/step
70short/step's Avatar
Oven cleaner will work if you plan on painting it like 68 short step did.
But it will turn it colors you dont want if you want to leave it bare aluminum! So Dont use OVEN CLEANER!
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 04-22-2006, 05:28 PM   #15
ratrod67
ratrod67's Avatar
This is what you want to use.
http://www.eagleone.com/pages/produc...=1001&cat=5006
ratrod67 is offline   Reply With Quote
Old 04-22-2006, 07:41 PM   #16
Joeys Toy
Joeys Toy's Avatar
Use Aluma Brite at work on diamond plate aluminum plates on exterior of truck. Removed all stains. looks good. just spray it on and let it do the work. Think we got it at B-Line.
Joeys Toy is offline   Reply With Quote
Old 04-22-2006, 10:26 PM   #17
wibilly
wibilly's Avatar
most boat shops will have products to safely clean and pollish aluminum as well
common sense isn't so common anymore
wibilly is offline   Reply With Quote
