Old 04-18-2002, 09:46 PM   #1
texnician01
texnician01's Avatar
Post pics of my project
Here is what my truck looks like at the moment. the primer that you see is the final coat on most things. finishing the doors, but the rest is basicly done. the box is at home so it's not in the pics but it is done too.
hopefully in a few weeks I'll have it painted and started to go back together.
1969 C-10 292 I-6 4 spd in the middle of a restoration. going to get a 327 and 3.07 gears but keeping all of the original parts so I can put it back to original later on down the road.
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
05 Harley Night Train
06 1200 Sportster (Wife's bike)
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
texnician01 is offline   Reply With Quote
Old 04-18-2002, 09:53 PM   #2
eric27
Post
Looks great. Just came from there and you are going to be proud.
1972 SWB, VIPER BLUE, TILT, POWER DISC BRAKES,350-AUTO, FACTORY AM/FM. 1970 FORMULA 400 FIREBIRD (HAS TO WAIT DUE TO MR. 72)- "If you dont use your head, you might as well have 2 a$$**"
1972 SWB, VIPER BLUE, TILT, POWER DISC BRAKES,350-AUTO, FACTORY AM/FM. 1971 Camaro SS factory 4 speed project car. " I LOVE IT WHEN A PLAN WORKS"
eric27 is offline   Reply With Quote
Old 04-18-2002, 11:05 PM   #3
chevy71super
Post
Looks like your truck is coming along nicely. One thing I learned is patience, do it right the first time. That's what it looks like you are doing!
71 Cheyenne Super 4X4 SB
72 Cheyenne Super 4X4 SB
72 Cheyenne 4X4 SB
chevy71super is offline   Reply With Quote
Old 04-19-2002, 12:11 AM   #4
Solver
Solver's Avatar
Post
Looks great so far!
Are you changing from original color and if so how did you change color on firewall. Would love to go from blue to red on my truck but looks like alot of work to change firewall color and down inside vent area without paint stripping off later. No way to sand and don't have sandblaster.
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 04-19-2002, 04:52 AM   #5
Tim Christian
Tim Christian's Avatar
Thumbs up
Looking Good!
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
Old 04-19-2002, 08:05 AM   #6
texnician01
Post
solver, yes we are changing color. it was pea green with a white top and we are going to a solid indigo blue metallic. this blue is a common color on GM trucks today, but I think it'll look great on this one. we ended up sandblasting almost everything because someone had tried to do some work on it before. the more we worked the worse it got. one time we had the cab hanging upside down in the shop so that we could work on the inside top of the cab. you can pretty much scuff sand everything and you should be ok as long as the old paint has a good bite. you may also give a self etching primer a try, that may work. we are going to paint the cowl area the same as the body, otherwise it would look funny. The firewall is black along with the rest of the engine compartment. That's my dad in the pics. I'm taking them. we have spent alot of time doing things right the first time and I agree that this is the best way to go. I started this truck when I was 17 and I'm now 19. so we've been at it a while. thanks for the comments
Nathan
55 chevy 4 door 150
47 Willys CJ-2A
[This message has been edited by texnician01 (edited April 19, 2002).]
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-19-2002, 09:00 AM   #7
meathead95
computer illiterate
meathead95's Avatar
Post
lookin good!
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 04-19-2002, 09:58 AM   #8
nosurf
nosurf's Avatar
Post
Looks great. Nice and smoooooooth.
1971 C-20 2wd, LB, white/copper
1964 Impala conv.
1957 Bel Air Wagon
1948 Chev 3100
1930 model A coupe
1929 model A speedster pickup
nosurf is offline   Reply With Quote
Old 04-19-2002, 10:04 AM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
Post
That looks great - should be awesome when you are done. It is always great to see when someone is able to do a project like this with a parent. If more parents could find a hobby to do with their kids, everyone would benefit.
1969 C20 4x4 with roughly 6" lift and 35's
residing near Rose Hill, Kansas
Yukon Jack's Web Pages
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-19-2002, 02:46 PM   #10
JW
Post
Nice work, going to be a grat looking truck when finished.
You take the pictures, how much work do you do? Or does "Dad" do most of the work ? LOL
Rust Tip: My truck had minor rust areas. I used Jasco Metal Etch, nasty stuff. Brushed it on, 15 min later washed it off, wire brushed down to metal. Primed with a epoxy primer, to keep any future rust from bleeding through, This primer is hard to sand. Primed with a normal auto primer, easy to work before applying color coat. Been two years and not a sign of returning rust or paint lifting.
Silver is the original color
72 Cheyenne Super, Fleetside, Shortbed,
Original Owner, Special Ordered
Northern Calif
350ci/340hp, Auto Trans, 3:70 Posi, Tow Package
Northern Calif
JW is offline   Reply With Quote
Old 04-19-2002, 06:19 PM   #11
texnician01
Post
no, this is MY truck so I do much of the work. it is sort of a trade off. he is better at welding and I am better at body work. there was plenty of each!! we both paint about the same so it is pretty even. Dad and I work together on most of the projects that we do. we're nearly inseprable, if one of us is working there are not many times that the other is not right there beside. that's ok cause the 55 chevy will be the next project and he owns that. it's a fair trade.
oh ya, and he took his pictures earlier with the other camera. I just took them to post on the board. lol
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-19-2002, 07:16 PM   #12
DarkFox1
in WAY over my head
DarkFox1's Avatar
Post
looks good, however, are your arms primered as well? how do you plan on painting them on the truck?
as everyone has said, do it right the 1st time. which is exactly what yer doin, not a surface left untouched, thats the way to go
Projects
Belair '71 C10 LWB to SWB conversion:C10 project page
65Chevelle pics coming soon
DarkFox1 is offline   Reply With Quote
Old 04-19-2002, 07:34 PM   #13
busterwivell
Post
Too cool! Way to go.......like your paint color choice, too. Let's see pictures soon in paint.
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 04-19-2002, 07:49 PM   #14
texnician01
Post
the frame is painted flat black and the front crossmember is smoke gray along with the rear axle, springs, and control arms.
the blue paint is a pearl but it doesn't show very well in the pic.
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
Old 04-19-2002, 09:24 PM   #15
DarkFox1
in WAY over my head
DarkFox1's Avatar
Post
oh, sorry heh, I thought that was primer.
I was gonna use a flat black on mine, infact I had some on it for a while, but then I came across the eastwood company and their OEM black epoxy spray, its $10 a can but its great stuff, I've used it on my entire frame suspension, crossmembers.. the whole 9 yards.
btw stupid question, I may have overlooked it.. but are you gonna be fleetside or stepside?
Projects
Old 04-19-2002, 09:54 PM   #16
texnician01
Post
This is going to be a fleetside...I might take pics of the box when I get home. It is already done and ready for the paint so we took it home to make more room in the shop and keep anything from happening to it. The closer we get to being finished..the more likely it is that someone will drop something on it or hit it....hate it when that happens..lol
maybe this pic of the paint will show up.
55 chevy 4 door 150
47 Willys CJ-2A
69 C-10, 340HP 327
55 chevy 4 door 150
47 Willys CJ-2A
70 Honda CL350
OIF2 & OIF7 Veteran
Nathan & Tiffany
