Old 04-17-2002, 07:47 PM   #1
Dean23
68cst_ss490
Dean23's Avatar
Question carb question
I have a 350 with a L-79 cam, 9.5 comp and headers. I bought a performer rpm and the recommended carb is a 750. Do you think that is too much carb or would an edelbrock 600 be better than the 750. And would you go with auto or manual choke.
Dean
edmonton,canada
68 c10, project in works,350, th350, plain jane.
SLOW AND STEADY GETS THE PANELS READY
http://communities.msn.ca/MyChevytruckpage
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
Old 04-17-2002, 07:52 PM   #2
Mountain Man
Post
You have a similar engine spec to mine. I had a 795cfm QJet, and replaced it with a 1406Edelbrock( which I drove for the first time last weekend). It has no hesitation, faster acceleration, and I believe that it feeds the engine more efficiently with the 600 , vs the 795. Just my opinion. Also, I had electric choke on the QJet as well as now with the Edelbrock.
72 C10 Cheyenne Super
Full trim
Factory tach dash
A/C dash
Factory tilt
350 / 350 power train - with Edelbrock components.
Mountain Man is offline   Reply With Quote
Old 04-17-2002, 07:54 PM   #3
69 longhorn
Post
Thats a pretty healthy cam,& you have the compresssion .......I would go for the 1407(Im guessin not a daily driver).....69
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-17-2002, 07:58 PM   #4
Dean23
68cst_ss490
Dean23's Avatar
Post
thanks guys, it wont be a daily driver. My boss thought it would be ok as well he said it is better to have too much than not enough carb. My boos is into hi performance as well. I just wanted the opinions from the guys on here. Cause they are gods.Lol. My boss has a 69 nova that runs 13.6's at 113.He ithrowing a 500 caddy into his 32 ford pickup.
Dean
edmonton,canada
Dean
edmonton,canada
a winter wonderland
Old 04-17-2002, 08:36 PM   #5
JW
Post
My engine is a 350 ci, 340 hp, cam, heads, ported, headers, alumn hi-rise, HEI, balanced, used a Holley 6210-3, 650 cfm spread bore replacement for the rochester.
Need a 2bl, sucks gas like there is a hole in the gas tank.
72 Cheyenne Super, Fleetside, Shortbed,
Original Owner
Northern Calif
Original Owner, Special Ordered
350ci/340hp, Auto Trans, 3:70 Posi, Tow Package
Northern Calif
JW is offline   Reply With Quote
Old 04-17-2002, 08:38 PM   #6
704x4
Post
my theory would be to use the smaller carb because the size of the primarys and secondaries on a qjet are a night and day difference than on the edelbrock.
i just had to say it because i just went through the problem of too much carb on my 350 (9.5:1 comp, but not that big of a cam)
with not enough carb it will only hurt high rpm, but i think you would be fine up to 6500rpm with the 600cfm edelbrock
70 3/4 ton 4x4
FOR SALE
Greene, IA
704x4 is offline   Reply With Quote
Old 04-17-2002, 08:39 PM   #7
Dean23
68cst_ss490
Dean23's Avatar
Post
I just want it for cruisin round the city on weekends and the odd trip. I am still lookin for a 700r4 so that would help economy on the hiway.
Dean
edmonton,canada
Dean
edmonton,canada
a winter wonderland
Old 04-20-2002, 07:20 PM   #8
Dean23
68cst_ss490
Dean23's Avatar
Post
ttt
Dean
edmonton,canada
a winter wonderland
Old 04-20-2002, 09:05 PM   #9
Desert Rat
Desert Rat's Avatar
Post
Im running a 600 Edelbrock on stock big blocks/i have 750 for 454 larger,and healthy application.I found the 600 to respond alot faster,but get the manual choke they are more performane they run fatter.and theyre cheaper that the electric chokes.
Desert Rat is offline   Reply With Quote
