06-06-2006, 11:14 PM | #1 |
firewall harness, what wires are these?
Sorry but no pic's on this one. I am looking for information on the harness that is located about 3 inches above the MAIN wiring harness, Just to the right of where the spedo cable exits the firewall. Looks to have about 5 wires in it. Behind the dash, it goes to a relay and the fuse box. Please help identify these wires. Goes on a 71 4x4 blazer with factory ac.
06-06-2006, 11:23 PM | #2 |
Truck junkie
Re: firewall harness, what wires are these?
Hey there I'm in Reno too. I'm going out to look at mine right now.
06-06-2006, 11:24 PM | #3 |
here you go.
06-06-2006, 11:25 PM | #4 |
call me at 358-3722
06-06-2006, 11:33 PM | #5 |
Truck junkie
Where does that go from there the relay on the inside next to the fuse block on mine is the horn relay. I have one wire in that location and it goes to the blower motor relay and since yours has factory ac it could be the a/c/ switch relay. Mine has no air.
06-07-2006, 03:21 AM | #6 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I believe it is the harness for the TCS (Transmission Controlled Spark) system.
Basically it's an emmissions thing. My harness was still still on my truck when I got it but the TCS solenoid was gone and the circuit was not functioning. I removed that harness when I switched to TPI.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-07-2006 at 03:23 AM. |
06-07-2006, 03:25 AM | #7 | |
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
06-07-2006, 10:35 PM | #8 |
PROJECT 7DEUCE
Mine went away when I put the painless harness in..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-09-2006, 08:32 PM | #9 |
Having issues
I went and looked at the two rigs in the driveway. My '71 (build date 05/71) with AC did not have this harnass, nor did it have the dingleberry on the transmission. Engine calibration code AQ. US Dept. of N.E.W and CA. certified
My '72 CST(build date 04/72) had it. Engine calibration code LM, federal and CA compliant. In the harnass there was the feed to the coil, and 3 other wires (that I noticed) that went to a plug, (whatever it plugs into is gone, no suprise there) then down to the transmission.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." Last edited by masterbeavis; 06-09-2006 at 08:36 PM. |
06-13-2006, 04:20 PM | #10 |
Having issues
On both of my rigs, one ear is broken off of each one.
HEI/tach pic shown here.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." Last edited by masterbeavis; 06-13-2006 at 04:21 PM. |
06-13-2006, 05:20 PM | #11 |
The LuvShack Garage
I have a full upgraded wiring system too, no help just a bump
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-13-2006, 05:26 PM | #12 |
Exactly what is a "dingleberry"
Shane
1993 K1500 350 5 speed 1985 K10 Silverado Vortec 406 5 speed (in body shop) "I been drivin' this '85 pickup truck Them buddies of mine call it a bucket of rust She's a little beat up but she still runs like the wind Yeah, kinda like me I been banged and bruisedBeen around the block a time or two But I'm runnin' like new goin' places I never been No, I ain't broke I'm just broken in" 1963 Dodge Townwagon(its amazng what 30 years and zero miles will do to a vehicle ) Member#20327 |
06-15-2006, 11:29 AM | #13 |
Having issues
its a thingie used in upholstery, its a little ball on a string, commonly seen (in the old days in cars driven by mexicans, and indian (not nativie) cab drivers in NYC. Also refered to "something" stuck to hair on a nether region of your backside that has balled up. I will let you draw your own conclusions.
Quando Omni Flunkus Moritati. The Man's Prayer: "I'm a man, but I can change, if I have to, I guess." |
