Old 06-07-2006, 10:28 PM   #1
Kantosensei
Side Widows will not roll up to top
My drivers and passenger side windows will not roll up completely. They are both about 1/16 to 3/16 of an inch from reaching the end caps. Is there a way to adjust or are my window regulators worn out? The rainy seaon has begun here in Japan and I am tired of riding around with a rain suit on. Any ideas are greatly appreciated.
Kantosensei is offline   Reply With Quote
Old 06-07-2006, 11:06 PM   #2
72CSTC5
72CSTC5's Avatar
Re: Side Widows will not roll up to top
Regulators are worn out would be my first guess. Do you have the upper weatherstrip in place around the top?
72CSTC5 is offline   Reply With Quote
Old 06-07-2006, 11:19 PM   #3
Kantosensei
Yes, I do have weatherstriping around the top. The windows will not reach the endcaps that are mounted to the top of the vent windows.
Old 06-07-2006, 11:30 PM   #4
72CSTC5
72CSTC5's Avatar
Take off your door trim panels and loosen all of the bolts that hold the window regulator in the truck. Roll your window all the way it will go and tighten everything again. This may or may not fix the problem. If not buy new regulators. They may be worn. Pics of the situation would help as well.
Old 06-08-2006, 10:07 AM   #5
makovai
makovai's Avatar
mine does the same thing, however mine is so worn out you have to push/pull on the window while rolling it to get it to go up or down. It one of the next things to fix. Luckily the regulators are fairly inexpensive.
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 06-08-2006, 10:23 AM   #6
ecameron87
Mine had the same problem. Turns out that the bottom of the window regulator (Where the glass is glued into) would hit the door where the felts are. Bend back the sheet metal on the door where the felts connect until it clears.
ecameron87 is offline   Reply With Quote
Old 06-08-2006, 09:47 PM   #7
71RestoRod
71RestoRod's Avatar
If the sheet metal screws holding the door panel trim are too long... that will also keep the window from raising all the way up.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod
71RestoRod is offline   Reply With Quote
Old 06-16-2006, 04:00 AM   #8
13lazer
13lazers' blazers
13lazer's Avatar
i was gonna say that, my anti rattles were hanging on my windows after i did complete teardown, wire wheel, grease, rubbers and felt, reassemble and adjust on my blazer doors last month and it took me a few minutes to see the problem. at least its only sheet metal.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
