Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 07-28-2006, 06:44 PM   #1
ducmons
ducmons's Avatar
72 GMC - Stereo Question
Hi guys. I'm new to the forum. Figured I'd ask around for advice. I have a 72 GMC Sierra Grande, and I've heard there are some cool digital radios that fit in the stock holes. I WILL NOT cut up my dash, but having a new radio would be kinda nice. Any of you guys found a good solution for a new radio that fits in the original openings? Thanks in advance.
ducmons is offline   Reply With Quote
Old 07-28-2006, 07:04 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: 72 GMC - Stereo Question
Custom Autosound makes a head unit that fits the factory opening. If I'm not mistaken it is an AM/FM unit with a cassette player that has the ability to control a remote mounted CD changer. I haven't heard from anyone who thought it was worth the $$$. I personaly mounted a unit in the glovebox and control it via a remote mounted to the steering column.
see ten is offline   Reply With Quote
Old 07-29-2006, 03:31 PM   #3
EROC
Active Member
I was'nt happy with the quality of the Custom Autosound either. Here's a pic of their unit. I ended up selling mine and putting the stock AM back in the dash and putting a CD player in the glovebox.
69 GMC 2500 Camper Special
88 S10 Pickup
04 Impala
I ship UPS from 24153
EROC is offline   Reply With Quote
Old 07-29-2006, 03:49 PM   #4
72highlander
Sophomore Member
72highlander's Avatar
who makes that glove box liner for the head unit.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 07-29-2006, 06:11 PM   #5
53burb
53burb's Avatar
kelsfine69 had them for a/c & non a/c...
53burb is offline   Reply With Quote
Old 07-29-2006, 09:04 PM   #6
see ten
WTB this ad
see ten's Avatar
Both of mine are Vintage Air glove box liners. I just cut a hole for the stereo and wrapped what was sticking out with some adhesive black felt.
Old 05-08-2007, 09:19 PM   #7
72GMC2500
72GMC2500's Avatar
ya just go with some kind of universal mount under the dash or in the glovebox if you dont want to cut your dash those are about your only options
Stephen
72GMC2500 is offline   Reply With Quote
Old 05-09-2007, 03:16 PM   #8
AceX
>130dB Moderator
AceX's Avatar
Already on it... http://67-72chevytrucks.com/vboard/s...d.php?t=240086
Originally Posted by AceX View Post
I'm currently tackling this problem in my dad's '67 El Camino. Firstly, we need to examine all your options at this point before making a decision.
Option 1:
You can install the head unit just as you showed, but I would place it level instead of at an angel, this will allow better access to the faceplate and make room for incoming and outgoing CD's.
Option 2:
You get a new headunit from Custom Auto Sound that will look very much like the original piece, but will have modern internals and provisions for a CD changer, iPod, and preouts for an amplifier. (Personally, I'm not impressed with these headunits, but they are basically the only thing on the market for this sort of application.)
Option 3:
You install the headunit as discussed in Option 1, but you run an infrared reciever to the dash so that the remote for the headunit can work properly if at all.
Another way you can do this is to run a "ribbon" wire arrangement from the headunit to the detached faceplate and then place it on your dash.
A "ribbon" wire looks just like an IDE cable from inside your computer. It's very thin and flat and probably an inch wide or more.
Option 4:
You get over your fear of cutting metal and make provisions for a new headunit where that old AM radio resides and then wire that puppy up.
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
