![]() Join Date: Jul 2000
Who has used these? Do they fit well?
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
I just got a set and tried them to see how they fit. They fit perfect. I'll be installing them as soon as I have time to go to the exhaust shop and get the rest of the system done.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
Mixup -- Is your engine mounted in the forward position?
Member since 2000
forward position, i thought they sat strait, lol, explain please, todays not my day for thinking
------------------ Mechanic @ California Concept Britney: 1970 2wd K/5 Blazer (Frame up) Jessica: 1967 2wd SWB (pops daily driver) Helga: 1972 4x4 3/4ton LWB (my daily driver) AIM:Alexmart1 Mountain View, Cali |
Check out the topic a few lines down called "Headers - what to use." See the picture of the black engine with shorty Sanderson headers posted by Slammed67? The motor mount bracket is mounted to the frame by two bolts. There are three holes for those two bolts. In this picture, he's using the rear two holes. My 69 2WD uses the front 2. Using the rear two holes, you get more room for header-to-frame clearance, and somewhat better weight distribution, but also a real tight engine-to-firewall clearance.
------------------ MikeB 69 C-10 Fleetside, mild 383, Dart Iron Eagle 180cc heads, Crane Energizer 266 cam and 1.6 roller rockers, Edelbrock Performer manifold and 600cfm carb, HEI w/ MSD components, 1986 front spindles/disc brakes, Vintage Air in-dash, lowered 2"/3".
Mike I believe its in the back holes.
![]() Join Date: Jun 2014
Re: DynoMax #86118 Chevelle Shorty headers
Has anyone tired these on a Munice or Sag 4 speed?
