Old 08-08-2002, 02:08 PM   #1
Paul Clark
Side Windows
Any kind soul(s) out there willing to talk me through the re-assembly of the side and vent windows? I took them apart and don't remember how they go together. Imagine that.
Also, the windows have a metal piece at the bottom. Looks like there's a rubber insulation piece in there. Is it just some rubber caulk stuff, or is it a rubber insulation piece?
Paul Clark is offline   Reply With Quote
Old 08-08-2002, 02:13 PM   #2
cali_surfer
cali_surfer's Avatar
The rubber strip that holds the glass in the regulator is available at GM dealers. I can't remember for the life of me what its called, but its available in two kinds, a thin version and a thick version. I can't remember what I used, but bought both since they were really cheap. Its available by the foot.
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 08-08-2002, 02:15 PM   #3
jostrans68
Jostrans68
jostrans68's Avatar
Hey your just in time Wes from Classichearbeat.com just posted that he has a video on door repair it will cover what you need I am going to order one myself
might check it out Wes is a great guy and truly loves these truck...Jack http://www.classicheartbeat.com/
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 08-08-2002, 03:24 PM   #4
johnnyp
Keepin' It Stock
johnnyp's Avatar
Here's some info from another member on installing vent window.
Putting the vent windows in is a lot tougher unless you know what to do. Put the main window back in and roll it all the way down. The rear track that guides the main window must be unscrewed. You will find two screws holding the bottom part in and one screw at the top backside of the door. Move the rear track and window as far back as you can. This gives ample clearance for getting the vent in position. Believe me if you don't loosen that rear track you will have a lot of wrestling to do.
Southpa
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
johnnyp is offline   Reply With Quote
Old 08-08-2002, 03:44 PM   #5
photoglg
photoglg's Avatar
The metal piece that the side window is mounted in is called a window sash and the rubber is called sash rubber. I just did my windows and the trick is to stretch the rubber on the glass then press the sash over the rubber after you let go the rubber will expand and hold the glass to the sash. On your vent windows buy the rebuild kit and the rivet tool
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 08-11-2002, 01:58 PM   #6
Paul Clark
Thanks guys.
What's a vent window repair kit? Sounds like a bunch of rivets, but where do they go?
Old 08-11-2002, 04:19 PM   #7
HEAVY CHEVY
BOWTIE FOREVER
HEAVY CHEVY's Avatar
Does anyone know how much the video is from Wes???
69 C-10 SHORT FLEET BED
350 4-BOLT/400 turbo
upper & lower molding
65 IMPALA 2-DR
283/POWERGLIDE
66 IMPALA 2-DR
hopefully 283/350
~ CAMELTOE ROCKS ~
HEAVY CHEVY is offline   Reply With Quote
Old 08-11-2002, 04:24 PM   #8
Paul Clark
I'll tell you - but you have to tell me what a vent window rebuild kit is first.
$25 plus S&H
Ordered one Friday.
Old 08-11-2002, 04:37 PM   #9
JJ
Lurking Member
While we're on the subject, once again does anyone have a nice clear picture of a one piece glass assembly? And those who have them would you venture an opinion? I'd like to hear from people who have some experience with them.
JJ
72 GMC 1500 350 4 Speed, stone stock baby!!!!!
72 GMC K-2500 350TPI 700R4
For those who fought for it, Freedom has a flavor the protected will never know.
JJ is offline   Reply With Quote
