Old 08-04-2006, 11:15 PM   #1
jeffs98
02 duramax with A/c comp. Leak??
I have an 02 duramax CC 4x4 with a eratic leak at A/c comp. Has anyone experienced a small eratic leak of freon at rear of compressor Pop off protection valve? I am Fairly sure that is where the leak originates from as it will loose freon suddenly and the tracer that i have in system is directly behind the compressor! I have had gauges on it and the pressures are correct! I just purchased truck and have receipts from Prev. owner and it has never had any a/c parts put on it, just the old add a can treatment! Thanks!
I also thought it would be a to check oil in compressor as well! I doubt it has had any put in since problem originated 22k miles ago!
1978 Chevy C-60 Pumper Truck!
1985 Chevy 4x4 project!
2002 Chevy Crew Cab DURAMAX 4x4!!
2002 Harley Road King BIG BORE STG. II, Thunderheader,Dfo Module!
2003 Chevy Malibu!
jeffs98 is offline   Reply With Quote
Old 08-20-2006, 09:27 PM   #2
jeffs98
Re: 02 duramax with A/c comp. Leak??
I finally figured out the problem!! It was the high Psi. switch not cutting out the clutch!I replaced the switch,vac'd, and charged the system and have 38 Deg. air again!
2003 Chevy Malibu!
