Old 08-11-2006, 04:02 PM   #1
makovai
makovai's Avatar
2WD vs 4WD
I'm putting a new radiator in my rig and i cant figure out if the radiator hoses (upper and lower) are the same from 2WD to 4WD. They have different part numbers at the auto store but they only have 2WD hoses. Anyone no the answer.....are they the same?
If it aint broke..............fix it till it is.
www.fast77.com
1972 - 330 hp crate, 11" lift with 39x18 mickeys.
3/4 ton, cross steer, 4 wheel disc brakes
1996 Z71 w/ 35's
makovai is offline   Reply With Quote
Old 08-11-2006, 04:14 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: 2WD vs 4WD
If a blazer is like a pickup, on 4x4s the engine is further away from the radiator. I think the bottom hose sometimes has to be trimmed on a 2wd so you might get away with it but who knows. I think I would find a store that had what I needed in stock or just have the correct parts ordered. Of course if you gotta get it going yesterday, do what you gotta do!
see ten is offline   Reply With Quote
Old 08-11-2006, 04:28 PM   #3
lazygaurd
Re: 2WD vs 4WD
The four wheel drive, regardless of truck or Blazer has the motor sitting closer to the fire wall than a 2 wheel drive. Stock upper rad hoses on a 4x4 are also 2 piece rubber hose with the metal sleeve above the fan.
lazygaurd is offline   Reply With Quote
Old 08-11-2006, 06:54 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 2WD vs 4WD
You won't find the 4wd hose at a parts store. The original was a metal tube (they get rusty) with 4-6" of rubber hose on each end. The NAPA guy found me a nice hose that worked great, but the part number is gone now so I can't tell you what it is. I think I had to cut a few inches off of it to get it to fit properly. Take a look at the 2wd, but I don't think it will be right. Take a look at later model (73+) upper hoses too. Have your rig handy so you can see what might work.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 08-11-2006, 11:56 PM   #5
makovai
makovai's Avatar
Re: 2WD vs 4WD
sounds like they are different. I think I'll take the hoses with me and match to whatever the best i can. Thanks guys
www.fast77.com
1996 Z71 w/ 35's
Old 08-12-2006, 12:07 AM   #6
jakeslim
Premium Level Member
jakeslim's Avatar
Re: 2WD vs 4WD
I am pretty sure I told the parts guy to give me a 77 blazer one when I first bought my 69 and it fit perfectly(4x4).
69 K5 CST stock- 350, 4speed
77 K5 - 383, auto, 6" lift, D60 front, 14b rear, 39" tsl's,
jakeslim is offline   Reply With Quote
Old 08-12-2006, 08:21 AM   #7
makovai
makovai's Avatar
Re: 2WD vs 4WD
kewl....thanks
I'll take my originals and compare them to that.
www.fast77.com
1996 Z71 w/ 35's
Old 08-12-2006, 08:29 AM   #8
msgross
msgross's Avatar
Re: 2WD vs 4WD
my napa guy said that there was an "extra cooling" setup??? My bottom hose had two numbers. My 4x4 took the longer 23" shaped like a big "L". I haven't installed them yet so I can't guarantee the fit.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-12-2006, 02:09 PM   #9
makovai
makovai's Avatar
Re: 2WD vs 4WD
well now i have a new issue. The upper hose for the '73 fit perfect but the lowerr hose is way off. And it was the correct one for that year.
Can one of you that have a stock setup shoot a pic for me?
Please!
www.fast77.com
1996 Z71 w/ 35's
