Old 04-16-2002, 08:08 PM   #1
Low68
Low68's Avatar
Post Ash Tray
Am I correct in assuming that the ash tray was removable in all the years? I got a 72 cab and can't get it out, and there are not any screws holding it in. Also is it the same as a 68 ash tray? Thanks
http://www.geocities.com/a68rod
Build Thread
Low68 is offline   Reply With Quote
Old 04-16-2002, 08:17 PM   #2
Andy4639
Old member
Andy4639's Avatar
Cool
Push down on the center tab in the ash tray and it will come out in less someone has done something to it before you. As far as them all being the same I don't know. Someone else will have to answer that one.
Andy
71's Are for ever!!! or 67,68,69,70,72
www.geocities.com/chevy71tpi/main.html]
www.picturetrail.com/Andy4639]
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-16-2002, 08:20 PM   #3
Low68
Low68's Avatar
Post
I am not talking about the ashtray itself, but the part that it slides in and out of. The part that screws to the dash and holds the ashtray in.
Build Thread
Old 04-16-2002, 08:36 PM   #4
Tim Christian
Tim Christian's Avatar
Smile
Mine don't come out either(1967)
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
Old 04-16-2002, 08:55 PM   #5
Mike C
Mike C's Avatar
Post
Open the ash tray, press down on the little lever and it comes right out. My 72 slides on plastic rails while my 70 has ball bearings, but they all slide out.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 04-16-2002, 09:08 PM   #6
72gmc1/2ton
Post
i believe he's talking about the ash tray mount. mine has two screws in it and the bottom is spot welded.
72gmc1/2ton is offline   Reply With Quote
Old 04-22-2002, 01:41 PM   #7
highwaydevil
Post
I've seen them both ways, some spot-welded, some screwed-in. Don't remember if it was a year thing or what...
1998 k1500 xcab
Had: 1972 blazer4x4, 350/350, factory a/c
highwaydevil is offline   Reply With Quote
Old 04-22-2002, 05:11 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
My 2 '70's and 1 '69 were screwed in...no spot welds. I only know this becouse the first longhorn had a better assembly than either of the other 2 trucks, so it has gone from truck to truck.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-22-2002, 10:05 PM   #9
Duallie
Duallie's Avatar
Post
Just had mine in and out to install a stereo, and it had two screws above the tray, and two more underneath, accessible AFTER you remove the heater controls.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
