The last 3 times my truck has been driven, if you turn the wheel all the way to the left (like when parking) it makes a noise from the left front that sounds like someone hitting the frame with a hammer or something like that. I know a description kind of doesn't help too much, but dose anyone have any idea of what I should look at? It has done it 5 or 6 times now, and it has gotten louder each time. Could it be something in the steering box? It is a 1970 2wd with power steering.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: Mar 2000
Jack the truck up and check all suspension and steering parts, I would suspect shot upper cross-shafts on your upper a-arm.
GMCPaul |
Hey, thanks, I will have to do that. I guess it looks like I will have to do the front suspension sooner than I planed. If that is the problem, is it safe to drive it like that for a while?
Check your idler arm
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
huh?
![]() Join Date: May 2000
It's definitely a worn/loose suspension part. In my case, my 85 Z28 did that all the time, and it was the ball joints. Do what Sir Paul said, and check all the suspension parts.
TJ
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
