Yellow truck club
Headers questions.....
My 59 has a power mustang rack front end and side mounted small block. The headers interfere with the brake pedal. The elbow on the pedal shaft just catches one of the 3 corners of the header flange. I think I can shorten up the collector and place a new flange turned a bit to miss the corner of the flange but I'm wondering about the shorty type block hugger headers I see on ebay. Will they work with the side mount and clear the steering shaft? What have you guys used with this sort of combo.?
Brian ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 09-17-2006 at 06:42 PM. |
Re: Headers questions.....
Entourrage, if you go with the shorty block hugger headers let me know. I have a new set of ceramic coated block hugger header I never used other then just bolted on my motor and pulled the back off. I ended having to go with a set of Camaro headers so I don't need them any more. If you want them, I will give you a good deal on them.
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
Yellow truck club
Hey Cal whats the deal... did the motor mounts interfere with them? What make and model# I'm interested let me know or pm me.....
Brian ![]()
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
When I mounted them I found out that block hugger header flange on the drivers hit the clam shell style motor mounts found on Camaro. I only had one of them bolted on before I found the problem. I see you have a mustang II IFS. They should work with any other style mount mounts. The headers are a generic brand I got off of e-bay. I paid $130. I sent a p.m. to you for the price I would like to get for them. Other then a few scuff marks and a very small ding they are like new. Here are a few pics.
We got a set for a big block that worked just fine with the MII front end we have. I don't have them completely installed yet but did install a couple of bolts to check for clearance. The only other problem I forsee is the steering shaft but there looks to be enough clearance for that also.
Bernie |
Hollister Road Co.
I have a big block in mine and had to redo the tubes due to the steering shaft. The block huggers wouldn't work.
That's concerning
![]() Bernie |
Hollister Road Co.
Those damn beer goggles always screw up the measurements. I never measure it right when I wear mine.
