Old 09-19-2006, 08:46 PM   #1
JayG
Formerly ADHDCARGUY
JayG's Avatar
Need Rear end suggestions
The rear end on my brothers '48 Chevy 5 window pu went out. Turns out it was a '55 or '56 rear end. Thought I had a chart on a bunch of popular rear end widths, but can't locate it! With his wheel tire combo he indicated had could use from a 62" to 64" width. What is a reasonably late model rear with that spec, small Chevy bolt pattern and maybe even disc brakes? He's located just north of Atlanta and will have a local rod shop do the swap. (He enjoys truckin', but he's not mechanically hip). Thanks in advance for the help.
Jay
67CHEVY SWB,355, built 700r, 5/7,9",posi 3.50,REAR BAGS,HOOSIERS, A/C.
54CHEVY - BURB, beginning construction(well, i gotta take it apart first!)
36FORD PU - WAITING
38CHEVY - 2DR SD,CHASSIS FINISHED
46CHEVY - BURB - waiting
JayG is offline   Reply With Quote
Old 09-19-2006, 11:04 PM   #2
CAL 58 GMC
CAL 58 GMC's Avatar
Re: Need Rear end suggestions
I used a 2003 chevy S-10 Blazer 10 bolt rear and udated everthing inisde using a Z-28 Carrier and ring and pinon gears. The later model S-10 blazers used disc brakes in the rear. The two wheel drive is 58" wide and the 4X4 is 60" wide. He's a picture.
CAL 58 GMC is offline   Reply With Quote
Old 09-25-2006, 11:24 AM   #3
1-ton of fun
polishing a turd
1-ton of fun's Avatar
http://50chevy.freeservers.com/Suspension_Widths.html
1-ton of fun is offline   Reply With Quote
Old 09-25-2006, 06:14 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
great suspension info
Brian
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-12-2006, 03:03 PM   #5
Daniel U
Daniel U's Avatar
I'm using an '87 IROC rear end with disc brakes and 3.73:1 Hope this helps. P.S. All of the 82-92 Camaros/Firebirds should have something to offer, depending on the brakes/gears you want.
Daniel U is offline   Reply With Quote
