Old 09-29-2006, 12:44 AM   #1
04 orange
04 orange's Avatar
Drop spindles 67-72?
My question is will it help me go all the way down layin frame with front spindles. When I first z'd the frame and drop the back we set it up with the frame on the ground front and back. i didnt think at the time that when rebuilding the front suspension with all new stuff it would lift it up as much as it did. Now the front frame sets 3in off the ground and the rear is 1in off. I converted every thing to 5lug so i have front spindles from a 72. Which brand of spindles are yall runing. Here are some pics of how i did the frame and the last pics isnt very good but thats how it sets with the front rebuilt with bags all the way down. tp:[IMG][/IMG]//67-72chevytrucks.com/vboard/attachment.php?attachmentid=217391&stc=1&d=1159503158[/IMG]
04 orange is offline   Reply With Quote
Old 09-29-2006, 01:33 AM   #2
jimmydean
jimmydean's Avatar
Re: Drop spindles 67-72?
What bag mounts are you running? I am using the bag cups from Suicide Doors as they are and my truck doesn't go as low as others. Some people have trimmed the bottom cup down to an inch, that might help as well as drop spindles.
I am running the 67-70 spindles from GMC Pauls (McGaughys).
jimmydean is offline   Reply With Quote
Old 09-29-2006, 01:38 AM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
If you need 3", spindles should give you that in the front. That and a small c-notch in the rear should lay you out again.
Looks like you've come a long way already- keep us updated.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-29-2006, 11:31 PM   #4
04 orange
04 orange's Avatar
I have the Suicide Doors front bag plates and cups with contitech 2500 bags and stock spindles. Hopefuly i can find some drop spindles at goodguys on sat. Heres a pic of the front.
Old 09-30-2006, 05:35 AM   #5
gringoloco
A guy with a truck
gringoloco's Avatar
Yank those lower bumpstops and trim the height on your cups. There's more to be had in your current setup.
-Chris
-Chris
Old 09-30-2006, 09:56 AM   #6
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
-Chris
Agreed. Cutting the cups down should get you at least an inch, maybe 1-1/2". Cut those, and get some drop spindles and you'll be back where you want it.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-06-2006, 11:17 PM   #7
Silver-stroker
Good pictures!!! I have a 67 and the previous owner installed front disc brakes with stock spindles. I recently bagged the front with Slam RE-7' which have built in bump stops. I cut the the cups down an inch but would like to drop it lower. I'm wanting to put on a set of 2.5 inch drop spindles. I've heard talk about people putting 71-72 spindles on a 67 How can I tell what year my current spindles are? Are the spindles marked in any way indicating a year? I'm confident the stock steering linkage is still a 1967.
Any information would help?
Silver-stroker is offline   Reply With Quote
Old 10-07-2006, 12:09 AM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
If you have discs, you have at least '71s- or aftermarket. You can get 73-87 stuff even cheaper. Have to use the newer ball joints though, but I figure, while you're in there... might as well.
-Chris
Old 10-16-2006, 11:24 PM   #9
72LoBurb
Yup, I'm comp-useless
Bell-Tech makes a 3 inch drop spindle for our trucks and is what I have on my 'burb; I believe the part number is #3100.
No bags yet, but hopefully soon(within a year).
Correction, part #3120
72LoBurb is offline   Reply With Quote
Old 10-17-2006, 02:25 AM   #10
el curioso
el curioso's Avatar
Question: Is it safe to do what he did with the rear cuz I have been conteplating back 1/2 my short bed but this seems a much easier way of doing that?
!! I hope I didn't just open a can of worms !!
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
