Old 10-01-2006, 02:51 PM   #1
wildmanaaron
Template or dimensions for 73-75 Blazer Doors??
Is there such a thing as a diagram or dimensions for properly cutting the doors like originally done on the full-top 73-75 Blazers?
I had seen that someone mentioned this but I can't find any thing to back that up.
Also I had heard that the brackets at the bottom rear of the window frame were made into the doors on the earlier models as well, even if it was a Truck door. Does anyone know anything about this?
Aaron C.
wildmanaaron is offline   Reply With Quote
Old 10-01-2006, 10:00 PM   #2
Jonboy
Slots go on anything!
Re: Template or dimensions for 73-75 Blazer Doors??
The GM replacement for a Blazer door was a truck door, an insert for the rear of the door, and a template of where to cut. On my 77, I used the old doors as a template of where to cut, tepad it off, and cut them using a pneumatic hacksaw. I am sure a sawzall with a metal bit would work just as well. My truck was already cut when I bought it. They used the plastic door cap as a template in the rear, and used a long screw to hold it down to the rear track of the window (the one that bolts to the back of the door shell). I have tried to save the inserts from an original '75 door on another project, and ended up destroying teh door and insert. It isn't really necessary, if you can weld in a strap or something similar. Hope this helps some.
Old 10-01-2006, 10:02 PM   #3
rcbildr
rcbildr's Avatar
Check this out. http://www.coloradok5.com/full-conve...nversion.shtml
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 10-01-2006, 10:52 PM   #4
wildmanaaron
Originally Posted by rcbildr View Post
Yes I have this website already saved. It is a little helpful. My 1981 Blazer already has the full top done. Plus I have the doors already cut, but they need replacing due to the Rust Monster. I may make a template from cardboard as to where I need to cut the doors off.
As far as the little brackets go I just want everything to look as close to original as possible.
