Old 10-08-2006, 04:55 PM   #1
halffast blazer
halffast blazer's Avatar
engine swap, what fuel pump?
i have an '81 k5 4x4, and i have installed a 5.7l fi engine out of a 94 c1500. i am now trying to figure out which way to go for the fuel pump. what year k5 came with fuel injection? i assume they had an in-tank pump. would that be a bolt in swap, or did they change the tanks. any info will be helpful.
67 Chevrolet C10 StepSide
81 Chevrolet Blazer 4WD
82 GMC Jimmy 2WD
halffast blazer is offline   Reply With Quote
Old 10-08-2006, 06:53 PM   #2
edman87
junk collector
Re: engine swap, what fuel pump?
87 up k5 had fuel injection. Don't know if tank is different or not, as both mine are FI. The tbi doesn't require that much pressure, so an inline elec pump will work fine if you don't want to put pump in tank.
'87/89/76 K5 in progress
'99 K2500 short crew
'91 camaro rs
'98 jeep tj
'52 willys cj3a
edman87 is offline   Reply With Quote
Old 10-09-2006, 08:24 AM   #3
Jonboy
Slots go on anything!
The tanks are the same as suburban tanks, those are a lot easter to find around here.
Old 10-09-2006, 10:11 AM   #4
edman87
junk collector
A k5 tank mounts behind rear axle, a sub has saddle tanks. They are way different. That would be the reason the k5 has has a flat floor and subs have a hump under the seat like a truck.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 10-09-2006, 01:08 PM   #5
Jonboy
Only the pickups have saddle tanks.
Old 10-09-2006, 01:44 PM   #6
bagged74
its just $$$$$
bagged74's Avatar
Originally Posted by edman87 View Post
a sub has saddle tanks. They are way different. .
Not true!
bagged74 is offline   Reply With Quote
Old 10-09-2006, 03:58 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Any pump from a TBI motor will work on the sending unit from a '87-up Blazer/Burb.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-09-2006, 04:06 PM   #8
edman87
junk collector
OK, looks like I am wrong on this one. How do some subs have dual tanks? Some do have dual tanks, right? I havn't messed with a sub in a loooong time. I remember pops sub having a 40 gal single tank, so I guess you are right, no way a saddle tank could fit 40 gals. Also no way a 40 gal tank would fit a K5.
I WAS WRONG!
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 10-10-2006, 06:06 PM   #9
Captkaos
Captkaos's Avatar
Suburban only had rear tanks. 25, 31 or 40 gallon were availible.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 10-10-2006, 07:48 PM   #10
halffast blazer
so if i have the entire sending unit/pump assembly from the 94 truck, i can use the pump with my blazers sending unit? or will i have to have the sending unit from a fuel injection blazer?
82 GMC Jimmy 2WD
Old 10-10-2006, 08:03 PM   #11
edman87
junk collector
those 2 pumps would be the same, right? The top part that sits on the tankmight be different, but I think they are the same too.
'91 camaro rs
'98 jeep tj
'52 willys cj3a
Old 10-11-2006, 03:08 PM   #12
Captkaos
Captkaos's Avatar
I can't say for 100% that the sending unit it the same, I thing it was up to 92, but... The pump will definitely work. I will be using a Corvette pump on mine.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
