Old 10-14-2006, 06:01 PM   #1
bad_turbo
turbo enthusiast
bad_turbo's Avatar
'67 burb lift kits
Just acquired a '67 suburban 4x4 1/2 ton. None of my local offroad shops can get lift kits for it. Can anyone recommend a place to order a 6 inch lift kit for my burb?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 10-14-2006, 07:51 PM   #2
69CvyPickup4x
69CvyPickup4x's Avatar
Re: '67 burb lift kits
check out www.offroaddesign.com
69CvyPickup4x is offline   Reply With Quote
Old 10-20-2006, 09:20 PM   #3
bad_turbo
turbo enthusiast
bad_turbo's Avatar
no luck there, I'll keep searching
Old 10-21-2006, 04:29 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have a '67 K/10 Sub myself, I wanted to put big El Rancho springs on it but the guy at the spring shop said I'd be better off having my original springs re-arched. Something about the spring mounts being in the wrong place for the after market products which are designed for the later model years.
'68OrangeSunshine is online now   Reply With Quote
Old 10-21-2006, 07:20 AM   #5
Americanrider
http://www.spring-man.com/
These guys can make it for you, anything from under to way over stock and they will also re-arch your old ones. I priced a new stock set for the front of my K-20 around 175 each, rears where 225 each. That was from the Tacoma store but Portland OR. will be closer to you.
Americanrider is offline   Reply With Quote
Old 10-21-2006, 01:15 PM   #6
kylejamers
ive gotten components made from this last link
and without a hitch, timely service, i would return
kylejamers is offline   Reply With Quote
