Old 10-15-2006, 04:46 PM   #1
1969k10stepside
Question 67-72 and 73-87 Suspension
I am wanting to put a lift on my 69 K10 and I found a cheap lift for a 73-87 Chevy and my question is will it fit,is the suspension the same?My rear springs are no good and I will need the springs off it to,will they work?
1969k10stepside is offline   Reply With Quote
Old 10-15-2006, 06:43 PM   #2
b454rat
Re: 67-72 and 73-87 Suspension
The fronts won't work, yours is 45-46" or something, and the newer style is 48". You can move the mounts to get them to work, but I never messed with a 67-72 truck, so don't know anything aboot them. The rears I think will work, IIRC they are 52s. Make sure whatever kit your getting has 52s. Might want to measure yours to be on the safe side.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 10-15-2006, 06:50 PM   #3
qksilver
definity measure then check them out, some of the springs are also wider
qksilver is offline   Reply With Quote
Old 10-15-2006, 10:40 PM   #4
cypressbog
Go Pack Go!
Recurve the springs to fit the shackels and it gives you additional lift.
cypressbog is offline   Reply With Quote
Old 10-15-2006, 10:54 PM   #5
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
and the worst ride evar!!!!!!
the 60-72 springs are 44" the newer 73+ stuff is 48" long, the 60-66 springs are slightly narrower and usea no lip bushing, the 67-92 stuff the springs all use the same bushings.
dont buy the 3 layer ezride tough countries, they are soft and flexy but settle 1.5-2" and bend into a W real fast.
trkklr77 is offline   Reply With Quote
