Old 11-01-2006, 02:09 PM   #1
Ram-Man
Ram-Man's Avatar
The birth of trailing arms
Well I saw the 2" x 3" tube trailing arms ece is selling and thought WOW $500 for them. Granted they are bolt on with u-bolts and spring cups but I'm gonna try my handywork at a pair. I picked up what I need for $40 at the local steel supplier. Here is the start of them I got them cut with a little head scratching using my old ones as a pattern, we'll see how they turn out. I'll keep you updated.
Ram-Man is offline   Reply With Quote
Old 11-01-2006, 02:12 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: The birth of trailing arms
sweet.. keep the updates coming
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 11-01-2006, 04:44 PM   #3
70short
Very Nice!!!!!!!!!!!!!!!!!!!!!!!!!1
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 11-01-2006, 06:12 PM   #4
72slam
72slam's Avatar
Hi everyone, This is my first post. I'm the new guy. I'm really glad this topic came up. I am planning on doing the same thing myself except without the bends because I'm going to lower my truck to the ground. When I put the stock arms up to the frame the pitch is real high on the arms pushing the axle forward of it's original position. I hope you understand what I'm talking about. I definatelly will keep track of this post. Thanks, Dan
72slam is offline   Reply With Quote
Old 11-01-2006, 06:31 PM   #5
lpaine
lpaine's Avatar
Those look really beefy,way better than original I'd bet, and it'll probably cost 1/3 of an aftermarket set, not including your time of course. Nice.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 11-01-2006, 07:09 PM   #6
krue
Designated A-hole!
krue's Avatar
Look good, and welcome to the board slam72.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-01-2006, 07:33 PM   #7
ratrod67
ratrod67's Avatar
Be sure and take a bunch of pics. Would be nice for a FAQ post. I'll be watching as well.
ratrod67 is offline   Reply With Quote
Old 11-01-2006, 07:34 PM   #8
1LoC10
Insert Title Here
1LoC10's Avatar
LMC sells them for $299 still alot more than you will be paying, but cheaper than ece
http://www.lmctruck.com/features/cb/CBCR1.htm
BOBBY
_69 SWB_
Old 11-01-2006, 07:58 PM   #9
b&a72
Active Member
b&a72's Avatar
ECE sells there's for 499.00 a pair a LMC are 299.00 each. But still expensive either way you look at it.
b&a72 is offline   Reply With Quote
Old 11-01-2006, 08:38 PM   #10
72CSTC5
72CSTC5's Avatar
get with bagged74 he built his from sratch too the same way.
72CSTC5 is offline   Reply With Quote
Old 11-01-2006, 09:01 PM   #11
Ram-Man
Ram-Man's Avatar
I will keep updates on these. I rounded the ends tonight in front of the bushings so they don't rub in the mounts. Hopefully I will get the holes drilled and welding done this weekend. The cheapest new set I have seen is $449 for a pair.
Old 11-01-2006, 09:37 PM   #12
7387chevys
Great start What are you going to use for pivots though?
Shane
7387chevys is offline   Reply With Quote
Old 11-01-2006, 10:25 PM   #13
roj2323
anyone ever seen or have pictures of the LMC ones? the catalog image is horably pixelated?
ondrew
roj2323 is offline   Reply With Quote
Old 11-02-2006, 08:02 AM   #14
Ram-Man
Ram-Man's Avatar
I'm going to get the poly bushings that come without the metal housing or cut off the metal housing off the standard bushing and use either dom or standard pipe which ever is closer in size.
Old 11-04-2006, 07:04 PM   #15
Ram-Man
Ram-Man's Avatar
I got the holes drilled & the butts welded up now I have to wait for my bushings to make sure I have the right size pipe for the pivots so far so good. The biggest expense so far was a couple decent drill bits.
Old 11-04-2006, 08:43 PM   #16
qksilver
I was curious, when ECE designed the aftermarket trailings arms why do you still have to have a block for lowering? With all the other suspension stuff they sell why wouldn't they offer trailings arms that don't need a block, they would look a lot cleaner and maybe a little stronger.
qksilver is offline   Reply With Quote
Old 11-04-2006, 08:59 PM   #17
Ram-Man
Ram-Man's Avatar
I dont know? I just kept them the same as the factory ones. I studied the ece picture for quite awhile to try to duplicate them. I bought 4" drop Belltech springs so I dont plan on using any lowering blocks. I was going to make a less of a curve on them then decided to keep them the same as all the other ones. Maybe there is a reason. After I get them on I could build another set with a little different design and see how they look. The second set would be alot easier to make.
Old 11-04-2006, 09:17 PM   #18
roj2323
speaking of springs are those things chromed or stainless? excelent work btw. would you be up for making a few sets for board members? i'd love a set.
ondrew
Old 11-04-2006, 09:37 PM   #19
"67"StepSide
Junior Member
"67"StepSide's Avatar
Thumbs up Re: The birth of trailing arms
Looks great!!! make a few pairs and sell them on the board,I'll buy!! I have wanted to ask you , I'm redoing my arms and ece sells that renforcement kit, why no strips to box the sides in? should I have some made up or is what they give you enough? THANKS JOHN
"67"StepSide is offline   Reply With Quote
Old 11-04-2006, 09:45 PM   #20
1LoC10
Insert Title Here
1LoC10's Avatar
In the November issue of SportTruck the one with the red 68 on the cover... theres a bunch of pages with products for our trucks and they show the arms there
BOBBY
_69 SWB_
Old 11-04-2006, 09:47 PM   #21
Ram-Man
Ram-Man's Avatar
Thats my only concern if I should reinforcent the sides or not. I'm pretty confident with my welding. I like the clean look of these like the ece ones. I think the tubing would bend before the welds would break. My only hold back from selling them is the liability if something broke on them.
I do plan on closing the ends up but I am going to leave that til the end to make sure everything works with the pivot points.
The springs are powder coated silver.
Old 11-04-2006, 11:40 PM   #22
jp-n-mallory71
jp-n-mallory71's Avatar
what thickness of metal did you use? i've seen a guy put a backing strip on the longer sides of the tube and leaving a 1/8 gap so when he weld the pieces together it penatrated all three pieces giving it less of a chance for the weld crack
jp-n-mallory71 is offline   Reply With Quote
Old 11-05-2006, 12:09 AM   #23
PBFAB.COM
PBFAB.COM's Avatar
The arms look very nice! If it were me, I would go ahead and do the re-inforcement plates. There will be a lot of stress on that weld... better safe than sorry!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 11-11-2006, 07:12 PM   #24
Ram-Man
Ram-Man's Avatar
Well, They are about done except for paint. $500 for a set looks like a bargain after I look at all the time I have into these. The poly bushings were about 1/16" of an inch too large for the 1 1/2" pipe for the pivots so I chucked them up in the drill press and took off a 1/16" with sand paper and flat files. This was time consuming. Here are some more pics if anyone wants to take a shot at building a pair.
Old 11-11-2006, 07:13 PM   #25
Ram-Man
Ram-Man's Avatar
One more view.
