Old 11-06-2006, 12:22 PM   #1
Flatty
towing with a 4wd?
I want to get a 67-72 Chevy or GMC pickup truck to build into a tow rig... I plan on towing a flatbed car trailer with a built FJ40 rockcrawler on it. Here is my dilemma...
I started this plan with the intention of swapping in a cummins diesel motor, but the total cost would have been VERY high, so I put a stop on that one.
My other option is this: Vortech 6.0L with a 4L80E behind it running to a 205? and then off to a dana 60 in the rear and a 44 up front. I will rebuild all the suspension, and throw some 4" lift springs on there (probably custom made for its purposes). I plan on running a set of 35's on 17" wheels.
Here is my question to you. Do you think this would be able to tow a flatbed with no problems? Does anyone here tow with one of these types of trucks? What issues do you run across?
Dima
Flatty is offline   Reply With Quote
Old 11-06-2006, 03:43 PM   #2
TP from Cntl PA
TP from Cntl PA's Avatar
Re: towing with a 4wd?
Dima
I towed a bumper pull with my Cummins truck..........Don't have a gooseneck hitch in that one. Pulled alot of farm equipment with it though. Works great for that.
My '71 K-20 will probably see some trailer time, although I built it for more the same thing as the Cummins truck, pulling farm equipment, but I do have a reciever and gooseneck hitch on it too. So it will be only a matter of time before I back into the gooseneck deck over or cattle trailer with it. Won't get there in a hurry with the little 250 Inliner, but it will get there
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck
'71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel!
'69 3500 GMC 305V-6/4spd, Still under reconstruction..........
Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!!
TP from Cntl PA is offline   Reply With Quote
Old 11-06-2006, 04:03 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
I've towed this tractor before with my 69 with no problems.
I've also towed a horse trailer and a roughly 18 - 20' trailer loaded with hay with no problems.
If I were going to regularly tow, I would make sure to do upgrades to my truck's brake system (I'm all drums right now) and make sure my trailer had brakes.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-06-2006, 06:37 PM   #4
TP from Cntl PA
With brakes on the trailer, even discs or drums in the front wouldn't matter IMO. Set the brake controler up so the trailer "Grabs" a bit harder and go on your marry way. Personally, I wouldn't own a trailer without brakes of some sort.
Old 11-06-2006, 07:25 PM   #5
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Sounds like you have a good engine/tranny/axle combo picked out. It would pull a flatbed trailer no problem. As long as it's not longer than 18ft it should do OK. Any bigger/heavier and you'll want a brake controller and probably disc brakes up front. I never had problems towing with my 2wd, hauled anything from pipe to hay on a flatbed bumper pull trailer. Only thing I need to do now is get the gooseneck plate welded in and wire up the trailer brake controller.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 11-07-2006, 03:13 AM   #6
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I believe board memeber "Bram" built himself a very nice "beefed up" 72 Cheyenne Super K20 hauler. I believe he uses a gooseneck/fifth wheel setup...Can't seem to find any pics tho.
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada!
- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs
- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 11-07-2006, 11:29 AM   #7
Flatty
Well, here is the deal... I am looking to buy a house, and move in the next few months. Then I will get a truck and swap in a 6.0L with a 4L80E behind it. I just have to have it done by August for my trip out to Moab. The cummins swap is going to be too time consuming right now, but the other route is going to be just fine.
DIma
Old 11-07-2006, 06:49 PM   #8
JAKES 68GMC
Aluminum slot wheels rule...
A Cummins would pull the trailer a lot easier than the 6.0 V8. The 6.0's are wimps when it comes to towing, IMO. But, when light, your 67-72 should be a rocket ship.
JAKES 68GMC is offline   Reply With Quote
Old 11-07-2006, 08:32 PM   #9
TP from Cntl PA
I didn't want to bring it up...........But IMO, for towing I'd go with an old school 383 over a new 6.0
My grandfather has a 6.0 in his 2500 Chevy and its a weakling towing, but he tows far more weight with his than just a rock crawler on a trailer, so I really can't honestly say.
Old 11-07-2006, 08:42 PM   #10
gmcman7202
Active Member
gmcman7202's Avatar
with the new 6.0, isnt there gona be alot of wires and crap involved? wouldnt a built sbc or bbc of that era be much better, of course with all todays addons. i built a 400 sbc with a sm465 behind it... has alot of balls and torque, but ihave not towed with it yet. also the cost of the 6.0 and 4l80e is up there isnt it?
gmcman7202 is offline   Reply With Quote
Old 11-07-2006, 10:32 PM   #11
2wdBlazer
The Blazer King
2wdBlazer's Avatar
The question really is why pull an FJ when you can pull a Blazer? Ha ha.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 11-08-2006, 09:44 PM   #12
ND_guy
Tool Addiction=Money Shortage
ND_guy's Avatar
Got some picks of the FJ?
ND_guy is offline   Reply With Quote
Old 11-09-2006, 02:43 AM   #13
hogrocket
Junior Member
Iv'e pulled on a trailer other 3/4 ton trucks and my 77 FJ40 (which are lighter than a 3/4 ton) all over the place with my 70 K20 350-4 speed. I do have disk brakes up front. If all your pulling is your cruiser---no worries. M
hogrocket is offline   Reply With Quote
Old 11-09-2006, 02:58 AM   #14
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
WOW, yep. LOL at 2wd. Blazers post!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
