Old 11-10-2006, 04:49 PM   #1
ocbaud
Garage Queen Material
something new broke on the truck
so i decided i wanted to drive the truck back from lunch to work. drive it for like 5 minutes and decide not to.
get back home and decide to pop the hood and make sure everything is alright, i see a big wet area on the drivers side inner fender.
my brakes are leaking, where the master cylinder and booster meet.
WONDERFUL
ocbaud is offline   Reply With Quote
Old 11-10-2006, 06:38 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: something new broke on the truck
I hate when that happens. The rear seal on my master cylinder started to leak like 5 minutes after I put my new 454 in there. You know, just in time to mess up a swanky clean engine bay.
The good news is master cylinders are cheap and easy to install.
DirtyLarry is offline   Reply With Quote
Old 11-19-2006, 06:48 PM   #3
89 crew
I just fixed the steel line to the right front wheel. It broke just in the perfect place to spray brake fluid into the fan. You wouldn't believe all the places the fan blew it!
89 crew is offline   Reply With Quote
Old 11-20-2006, 10:19 PM   #4
lurch115
lurch115's Avatar
having a heater hose split from the clamp out 6 inches(the one on the intake) on a hard launch can make a hell of a mess too.....good way to get a tail gater off my back too....
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 11-21-2006, 10:42 AM   #5
EDOUBLE33
Active Member
EDOUBLE33's Avatar
I'm sorry to hear that something broke on your ride, but that is usually an easy fix. Also I'm glad you dont live around here because you trucks twin is about to be born.
EDOUBLE33 is offline   Reply With Quote
Old 11-21-2006, 02:52 PM   #6
ocbaud
actually, it isnt leaking there, its leaking where the reservoir and the mc meet at.
i think i'll just end up buying a new master cylinder for it
Old 11-21-2006, 08:34 PM   #7
magnethead
7000 #'s of american IRON
magnethead's Avatar
Try that, but with a leaky hydroboost hose..it rotted and sprayed at the fan as well as soaked the fender...
Then my MC started leaking
Now i have a leaky P/S reservoir main hose, and guess what- it leaks straight down onto the belts and fan!
needless to say, my engine bay is FAR FAR from emaculate.
magnethead is offline   Reply With Quote
Old 11-21-2006, 10:42 PM   #8
84 400
Sb 400 club
84 400's Avatar
yeah my old 85 used to leak from the resivor too but it was cheaper to buy a new one then go through the hastel of replacing those two o rings.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 11-22-2006, 12:41 AM   #9
magnethead
magnethead's Avatar
was yours HB? Mine's leaking at the hose clamp at the bottom of the canister (hose slips over fitting on canister), that part of the hose is rotted, or appears to be. The hose and clamp are constantly coated with a layer of P/S fluid right after being shut off. I just need to replace that hose, every other hose that i'm yet to replace in the engine bay, and all he belts.
