11-20-2006, 11:53 PM | #1 |
Blazer Rear Quarters
Looking for a previous thread or information on removing full rear quarters off a blazer.Wondering whats involved and difficulty rating.Thinking of taking my spare tub apart.
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
11-21-2006, 07:28 AM | #2 | |
Re: Blazer Rear Quarters
I would soak the bolts for a day in PB Blaster. Hope this helps somewhat. J.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
11-21-2006, 12:02 PM | #3 |
Drill out the spot welds in the front "b" pillar post, unbolt along the floor and wheelhouse area, grind and cut the rear weld to the floor and rear crossmember if my memory serves me right.
11-21-2006, 08:58 PM | #4 |
Not a bad nut after all..
I'm in a similar situation; I have remnants of a rough Blazer tub from which I'm saving the bed floor. I've already removed the front floor pan from the bed, and now I want to remove the bed sides. Where are these spot welds in the front "b" pillar post?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
11-21-2006, 11:42 PM | #5 |
The are at the very front leading edge of the quarter panel where it meets the back of the door. Look in that edge. You should be able to see them. Let me go in the garage and take a quick look to make sure.
11-22-2006, 01:08 PM | #6 |
Are these the right spot welds?
11-22-2006, 06:11 PM | #7 |
Nope, other side of 'B' post. J.
11-22-2006, 10:08 PM | #8 |
You can remove the quarterpanels by unbolting them and removing the tie-in welds that go from the floor to the B-C pillars. These are not spot welds but a tie-in the floor to the B-C pillars on the bottom inner edge where the pillar meets the top of the floor.
11-23-2006, 01:24 AM | #9 |
Thanks for the replys.Some good info here.Good Blazer rear quarters are hard to come by around here.
