Old 11-27-2006, 04:49 PM   #1
neil alan wicks
I lifted my 68 k20 6" drag link dont work help
I lifted my 68 k20 6" skyjaker they sent me a ajustble drag link, wrong tapper on ball joints. and not long enough if bolted on .I have original 4 bolt steering nuckle and manual steering box with the pitman arm swinging north to south is there an after market 4 bolt steering arm ? help please
neil
neil alan wicks is offline   Reply With Quote
Old 11-27-2006, 05:47 PM   #2
Blazer1970
Blazer1970's Avatar
Re: I lifted my 68 k20 6" drag link dont work help
With a 6 inch lift, you really need a raised steering arm at the VERY LEAST. I am not sure if anything is available for your closed knuckle axle. You should just convert it to crossover steering right now rather than spend money on a modified stock set-up that will be marginal at best.
Blazer1970 is offline   Reply With Quote
Old 11-27-2006, 09:52 PM   #3
neil alan wicks
thank you. Cross over steering would need a power geer box? "wich is in the same location as my manual . is there a power geer box that would bolt on excisting holes?
Old 11-27-2006, 11:49 PM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
For a 6" lift you should be able to use a dropped pitman arm (or raised steering arm) and a correct dropped draglink. You don't *have* to go crossover.
I'm thinking skyjacker might have sent the wrong draglink. See if you have a part # for it and compare it to thier website to see if it is right or not. From there you should be able to see what other steering correcton parts they have too.
You are going to spend less money getting the correct parts for your current setup than going x-over. Of course if you got the bucks and plan on wheeling the snot out of it, x-over would be best. It all depends on your plans for the use of the truck.
If you go x-over, you need a 2wd gearbox so the gear turns side to side rather than front to back. Both bolt up to the same spot.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 11-30-2006, 10:30 AM   #5
Yukon Jack
Post Whore
Yukon Jack's Avatar
I've never seen dropped pitman arms or raised steering arms for the closed knuckle axle. I was able to use the adjustable drop drag link on my 69. Too bad that doesn't seem to be an option for you. May be time to consider getting a newer front axle - gain you disk brakes, better turning radius and more steering adjustment options for your lift.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-30-2006, 12:07 PM   #6
Zoomad75
K5Camper
Zoomad75's Avatar
Duh, forgot the whole closed knuckle axle part. I'm betting they sent one for a more common 73/87 truck. No real good options for that old axle
Rob Z.
Old 12-01-2006, 04:40 AM   #7
earl87gta
earl87gta's Avatar
I have a sky jacker lift onmy 68 if I get time tomarrow Ill take a few pics of the steering for you .
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 12-01-2006, 01:47 PM   #8
earl87gta
earl87gta's Avatar
Ok here are the pica and I mesured every thing out for you . my pittman arm is 8in, the drag link is 18 in and the steering arm on the axle is 9in . I hope this helps you out. let me know if you need and other info or pics. my truck is a 68 2500 with d44 and closed knuckle.
Earl
