Old 11-28-2006, 09:24 PM   #1
2500HD
2500HD's Avatar
Front springs
If I cut one coil of the front spring how much lower will it be?
Can I cut less than one coil? Maybe 3/4 of a coil?
2500HD is offline   Reply With Quote
Old 11-29-2006, 03:12 AM   #2
bad_turbo
turbo enthusiast
bad_turbo's Avatar
Re: Front springs
probably need to know a little more about your truck. What year? Big or small block?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 11-29-2006, 03:50 AM   #3
leftcoast66
leftcoast66's Avatar
Re: Front springs
Ive always been told that in general it's about 2 inches for each coil.
leftcoast66 is offline   Reply With Quote
Old 11-29-2006, 01:50 PM   #4
2500HD
2500HD's Avatar
Re: Front springs
67 SWB with small block.
Old 11-29-2006, 04:47 PM   #5
crazy longhorn
Fabricate till you "puke"
Re: Front springs
2 1/2" for 1 round on that one..... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-29-2006, 07:53 PM   #6
70c10
67-72 Addict!
70c10's Avatar
Re: Front springs
Yes, you can cut less than 1 coil. I cut 1.25 coils and got almost 3" drop. I would not cut anymore than I did. I have zero problems.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
