What rearend would you recommend
I am thinking about changing the rearend from a 10 bolt to 12 bolt in my 82 GMC Stepside, is their any factory posi units in certain trucks or suburbans I should look for
Re: What rearend would you recommend
i like em tight kinda small and shapley. but,everybody's different...just kiddin man.trying to lighten it up on here a little bit.depends on what you want if you tow,or want fuel economy?overall tire diameter makes a huge difference.i had an 02 dodge cummins that had i think was a 3.53,i put 35's on it and made a big difference decreasing my towing grunt compared to 31's it came with.
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
I personally wouldn't swap rearend just to say I have a 12bolt.
http://67-72chevytrucks.com/vboard/s...d.php?t=217716 As far as finding an old truck with a posi in it, good luck in 2WD form. For chosing a limited slip, for drag I would go with an Eaton Clutch type which is the style that came in most all of the 12bolts.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
not doing it to say i have a 12 bolt. i just heard they were stronger. just trying to get some opinions
Born a Chevy Man
If you are not going to race it I would stick with the 10 bolt and go with the 3.73 gears. MO
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
Mad Scientist
I think the 10's are better axle wise with no taper....I think. Just posi and gear what you got. You really can't hurt either without huge (35" plus) mudders.
![]() 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
Oh,you can't buy that new
![]() Join Date: Apr 2000
going to a 12 bolt invloves careful measuring of driveshaft. it actually should be changed. at min you need to swap to a $25 'switch over' U-joint cause the caps are different sizes. . federated number #372. crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
hiway what kind of posi do you recommend
dang its hot
what are you doing with the truck? a 9" out of a ford truck will work. you have to re drill the axles and brake drums to the 5 on 5 pattern to keep your wheels
#10 | |
yeller
![]() I say upgrade your 10 bolt, and add an Eaton posi (pretty much the same as what GM used).
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#11 | |
Oh, and on half off day @ the boneyard, its around $75
70 GMC shortbed fleetside with a 72 chevy costume Last edited by 72dually; 12-10-2006 at 11:56 AM. |
Mad Scientist
Eaton, Moroso, factory, pretty much any clutch type....for smoothness. Stay away from the factory "hammer" types.
#13 | |
yeller
