Old 12-10-2006, 08:12 PM   #1
qksilver
71/71 Complete 1/2 SWB 4x4 frame and suspension
No Title or cab VIN plate
Frame is West Virginia rusted from transfer case crossmember back
I pulled the spider gears out to check gear teeth, have not put them back tgether in case some one wants pix
all parts listed below are in good shape, exceptions noted
3:73 open gears, rear axle housing and backing plates are rusted by spring perches, gears , axles and bearings good shape,
3:73 front axle complete with all steering linkages, hubs free, calipers seised
front and rear driveshafts
engine crossmember with engine brackets
transfer case stock 205?
4 speed trans with adapter complete not sure of condition, shifter boot not there, sitting outside
most of the spring perches are good shape, 2 have a little rust
P/S box complete with P/S pump with some of the brackets, pump turns free
The above is still mounted to frame with wheels, sheet metal was removed, engine and bell housing the rest is bolted to rusted out frame. Was driving until it wouldn't pass inspection because of frame rust.
$500 OBO, will part out.
Give me your e-mail and I will send plenty of pix
Thanks Steve
qksilver is offline   Reply With Quote
Old 12-10-2006, 08:47 PM   #2
1969k10stepside
Re: 71/71 Complete 1/2 SWB 4x4 frame and suspension
If it doesnt sell and you part it out I might be interested in the engine crossmember/brackets if its for a 350
Thanks,
Dustin
1969k10stepside is offline   Reply With Quote
Old 12-10-2006, 08:51 PM   #3
qksilver
It's straight across so it's for a V-8
Old 12-11-2006, 04:50 PM   #4
qksilver
Ttt
Old 12-11-2006, 09:24 PM   #5
6772king
6772king's Avatar
Put me in line for the whole frame,,, Where is the frame bad?? I need to see pics of that, do you have title and vin to go with it ??You can send pics to KING6772@msn .com thanks
67 chevy short step 2wd 427
71 chevy short fleet 4x4 396
72 gmc jimmy 2wd 377
71 chevy blazer 4x4 454
69 chevy longhorn 5.9l cummins
72 chevy 400 2wd custom camper
67 chevy lwb 4x4 454-in pieces
67 chevy panel soon 4x4-400
67 gmc dump 4x4 1 ton-305 WTF!!
72 chevy 3/4 ton 4x4 burb 350
70 chevy panel 2wd 302 5 speed tko
"THERE IS NO REPLACMENT FOR DISPLACMENT"!!!!!!!
6772king is offline   Reply With Quote
Old 12-11-2006, 09:54 PM   #6
qksilver
I will send tomorrow, no title and the frame is West Virginia rusted and repaired, great components but all the frame is good for is that everything is bolted to it. I will check on Vin I stripped the sheet metal off of it but I think I kept the plates
Pix sent 6772 king
Old 12-12-2006, 10:00 PM   #7
qksilver
Ttt
Old 12-12-2006, 11:47 PM   #8
1969k10stepside
Would you consider selling/shipping the 205 transfer case/shifter componets?
Old 12-12-2006, 11:53 PM   #9
qksilver
I have another transfer case with shifter . Have to dig it out from under my work bench. Sounds easy but there is a pile in front of it. Will do it Sunday.
It's out of a 71 K-5. Pm me your email and i will send pix
Old 12-13-2006, 10:09 PM   #10
qksilver
Ttt
Old 12-13-2006, 11:37 PM   #11
Down south truckin
Down south truckin's Avatar
how bad is it rusted? do you have any close ups of the rust damage? do you think it is easily repaired? thanks in advance Mike my e-mail is mtbbailey@yahoo.com
Down south truckin is offline   Reply With Quote
Old 12-13-2006, 11:42 PM   #12
qksilver
FRAME IS WASTED FRON THE TRANSFER CASE BACK...........west virginia.........
Believe me I have been looking for a SWB frame for a while.
It would be great for a 2 wheel to 4 wheel conversion or if you want to upgrade a closed knucle to an open knuckle.
If it doesn't sell in the next week I will part it out.
Old 12-15-2006, 10:43 PM   #13
qksilver
Ttt
Old 12-20-2006, 09:56 PM   #14
1969k10stepside
I will TTT this for you
Did you ever get those pics emailed?I havent got them if you have.
Oh,if you part out the frame I need a bracket off the back of it.I will try to get a pic of what I need.
