12-11-2006, 02:01 PM | #1 |
4-6 drop and wheels
My 4-6 drop and disc brake kit from ECE will be here tomorrow. I will be installing on a 67 short bed and my axles are being redrilled and the flange is being turned down.
My wheels are Eagle 211 (torque thrust look a likes). The front are 20x8 with 4.5 backspace and 255/40/20 Toyos. The rears are 20x10 with 5.5 backspace -- I plan to use a 1.25 inch spacer because 5.5 is to much backspace. The rear tires are 295/40/20 and my final backspace will be 4.25. I am 90% sure 4.5 is the correct backspace for the rear but Eagle only made the 211 20x10 with 5.5 and without cutting down the wheel studs the spacers need to be 1.25. The end result will be 4.25 backspace. the question is are the tires going to rub? Keep in mind I am using the narrower rear end. |
12-11-2006, 06:20 PM | #2 |
Re: 4-6 drop and wheels
Where did you oder you 4 & 6 inche drop? I've been looking and could only find 5 inche drop in the rear.
John |
12-11-2006, 06:27 PM | #3 | |
ECE sells 6" rear coils....I think they are about $115 for a pair. www.earlyclassic.com
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
12-11-2006, 07:05 PM | #4 | |
12-11-2006, 08:50 PM | #5 |
Early Classic is correct but I think GMS Pauls sells them also.
Scoti I not affraid of the inside. If I have a problem it will be on the outside. One correction is the rear wheels are 20x9.5 not 20x10. I hope that extra .5 inch saves me. Anyone else with any thoughts? |
12-12-2006, 09:20 AM | #6 |
Straight jacket required
Pics Pics Pics!!!
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
12-12-2006, 11:38 AM | #7 |
Before. The after is not done yet. I hope before Christmas.
12-12-2006, 12:42 PM | #8 |
Active Member
Nice truck
12-12-2006, 04:32 PM | #9 |
Seņor Member
Eagle 211 is available in 5" BS as well (PN# 2119-2983).
12-12-2006, 06:45 PM | #10 |
Eagles web site lists many backspaces. I originally ordered 20x5 with 5" backspace and 20x9.5 with 5 inch backspace. They sent 20x8 with 4.5 and 20x9.5 with 5.5. I questioned them and they advised they only made the 20x8 with 4.5 and the 20x9.5 with 5.5 regardless of what thier web site said. Many phone calls to Eagle confirmed what the distributor said.
12-12-2006, 06:50 PM | #11 |
12-19-2006, 12:23 AM | #12 |
It is done except the rear spacers are late..... They will be here Wednesday. My measurements tell me my 20x9.5 wheel with 4.25 total backspace and 295/40/20 tire will work great. After 4/6 drop, disc brakes, redrilling the axles, adding a 1.25 sway bar, cross shafts, ball joints, tie rod ends and idler arm I found a bad u joint on the test drive. So I will be replacing u joints in the morning.
12-19-2006, 01:52 AM | #13 |
Post those finished pics when you get it all squared away.
12-19-2006, 10:43 AM | #14 |
Active Member
Yes pictures please.
Jack |
12-19-2006, 11:50 AM | #15 |
I'd like to see and hear how that works out as well. I have the same kit for my burb and have been trying to figure out what BS I will need for 20's front and rear.
CPO U.S. Navy(Ret) 1972 GMC Jimmy 4x4 Custom 1972 GMC Jimmy 2x4 Custom |
12-19-2006, 02:16 PM | #16 |
Tot Roddin'
Can't wait to see the end result...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
12-20-2006, 06:51 PM | #17 |
Before and after.
12-20-2006, 07:05 PM | #18 |
What a tease . . .....
12-20-2006, 08:03 PM | #19 |
After--> No Workie!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
12-20-2006, 08:30 PM | #20 |
I cant get it to work for some reason. Can anyone post if I email to them?
12-20-2006, 08:43 PM | #21 |
It looks like you're trying to link it directly from your hard drive. You either need to upload it to a picture site then link it from there or, go ahead and use the "Manage Attachments" button on the "Reply to Thread" screen to upload it directly to the board.
12-20-2006, 08:51 PM | #22 | |
12-20-2006, 09:13 PM | #23 |
Nice setup!
12-20-2006, 09:44 PM | #24 |
Looks Great!
12-20-2006, 09:46 PM | #25 |
sweet , that change the look of your truck, really nice stance
