12-20-2006, 06:30 PM | #1 |
Mounting NP205 on frame
I was looking at the frame on my 1971 SWB K10 and it had a bracket on the passenger side frame that looked like the transfer case bolted too.It looks like the one on my 69 K10 that the Rockwell T 221 mounts to.Does the np205 mount there too?If anyone had any pics of a np205 bolted to the frame with pics of where all it bolts to I would really appreciate it.
Thanks, Dustin |
12-20-2006, 06:42 PM | #2 |
Re: Mounting NP205 on frame
Here is my 205 "Torque Bracket"
You can see it inbetween the two x-member brackets. That was the best photo I could find....
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
12-20-2006, 06:43 PM | #3 |
Post Whore
It is my understanding that they are the same bracket and mounting location.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-20-2006, 06:53 PM | #4 |
Thanks for the replies and pics so far.I just went out and inspected the frame and it looks like there should be a bracket on the drivers side frame to mount the transfer case to the frame also.Anyone confirm this?If it does mount there too I guess I will be looking for the bracket for that side because it isnt there.Words of advice...Dont buy a truck without the motor,transmission,or transfer case because finding replacements is a P.I.T.A.
12-20-2006, 07:24 PM | #5 |
.....didn't realize the project had gathered so much dust....maybe I need to get back to work!!!!!!
Misled |
12-20-2006, 07:34 PM | #6 |
Yep,thats what and where the bracket is,Thanks.BTW,is that frame powdercoated?
12-20-2006, 07:46 PM | #7 |
No, it was put on a rotisserie, blasted and "Chassis Saver" sprayed on by someone with far more talent with a gun than I have.....
Misled |
12-24-2006, 07:15 PM | #8 |
yessir, i have the original off of my truck with the 465/221 and another from a 70's parts truck with 465/205, the brackets are identical.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
12-26-2006, 02:45 PM | #9 |
brackets from a 87 suburban 465/205 and 67 465/rockwell look the same but bolt spacing and alignment are different.
12-26-2006, 08:43 PM | #10 | |
thanks for catching that!
12-29-2006, 10:11 AM | #11 |
what size bolts did you us on the side of the transfercase ??????
12-29-2006, 11:32 AM | #12 |
Glad someone else asked because I need to know also
01-23-2007, 06:40 AM | #13 |
01-23-2007, 10:14 PM | #14 |
The bolts are 5/8'' coarse thread, about 1 1/4'' long
