Old 12-21-2006, 06:20 AM   #1
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
Question serpentine belt conversion
I know there are few guys on here that have done this conversion. I have been searching and cannot find one post that goes through the whole installation, from donor vehicle thru special holes that need drilled to completion. Has any one got this info?
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
Old 12-21-2006, 06:34 AM   #2
Re: serpentine belt conversion
I used the setup off a 94 4.3 on mine. Nothing really to drill on my crate engine. swap out the water pump, alternator and power steering pump for those that run on the serpentine setup. I took the hi pressure connection off the old power steering pump and put it on the newer pump that way I can use a stock (68-72 style) line.
Old 12-21-2006, 06:40 AM   #3
sixty8c10
sixty8c10's Avatar
I have just heard that in order to use your old style heads there needed to be some drilling done to one of them in order to use a set up off a 4.3.
Old 12-21-2006, 06:52 AM   #4
Slammed70
Slammed70's Avatar
Only if you have the acclaimed "camel hump" heads that dont have any accessory holes in them.
ultra rare corvette option package
Slammed70 is offline   Reply With Quote
Old 12-21-2006, 07:26 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
if your heads have 3 holes on the front its an easy swap. other wise it can get real hairy.
68C15 is offline   Reply With Quote
Old 12-21-2006, 07:31 AM   #6
krue
Designated A-hole!
krue's Avatar
If you have the holes it's easy,
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-21-2006, 11:03 AM   #7
sixty8c10
sixty8c10's Avatar
good, got the holes....now let me get this right.......all I gotta do is get a new reverse flow water pump for my engine, then go get an entire set up off a 4.3, 5.0, 5.7, whatever......replace needed parts, clean it and bolt it up to my engine, install electric fans then its off to the races.....is that everything, or did I miss something?
Old 12-21-2006, 11:08 AM   #8
jerry moss
Born Psycho
jerry moss's Avatar
if you decide to do it, let me know. i have a serp set up off a 4.3 astro van.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 12-21-2006, 11:20 AM   #9
BUDDY
Global warming is a myth
BUDDY's Avatar
Thumbs up Re: serpentine belt conversion
That's it, except you could, (if you wanted to), also take the clutch fan off of the donor as well. Otherwise, that's it.
Later,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
Old 12-21-2006, 11:38 AM   #10
boraxman
Keepin an eye out
boraxman's Avatar
I have a serp system ready to install the same time I switch to my aluminium heads, but one the one head is a mounting bolt hole short. From reading about the conversion I understand you can get by without this bolt. I may "add" the hole anyhow for peace of mind.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-21-2006, 12:57 PM   #11
sixty8C10...The only thing you have to watch for is if you get a setup off a 4.3, they had some with different size lower/crank Pulleys. No quick way to determine which 4.3 does which. Measure the dept of your harmonic balance and compar it to the one on the 4.3. If they are the same thinkness harmonic you are OK, if the 4.3 is narrower, then you'll have to get another lower pulley to get them to line up.
Old 12-21-2006, 01:23 PM   #12
BUDDY
BUDDY's Avatar
Cool Re: serpentine belt conversion
That's good to know! Could you just pull the balancer from the 4.3 as well, or would that not be a good idea because it's from a 4.3 & not the 5.0 or 5.7 that you have for the swap? How could you source the new pulley that you might need?
Thanks,
Buddy
Henderson, NV
1990 K5 with 37's
Old 12-21-2006, 03:53 PM   #13
neonlarry
neonlarry's Avatar
P\S takes 4 holes, but like has been said you can get by without it. But if you have A\C you will have to have hoses made for the new compressor (you can't use yours). If you don't have A\C you will have to get an A\C delete pulley. You will also have to do some rewiring for the new alternator. You may or may not need to: bend a new fuel line, replace the thermostat housing, replace the fittings on the back of the power steering pump, get different radiator hoses, get a radiator with a heater return fitting. Thats all I can think of for now.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-21-2006, 04:44 PM   #14
Thanks,
Buddy
That I do not know. My guess would be no, but I am just a shade tree (with no tree) mechanic
Old 12-21-2006, 09:22 PM   #15
Slammed70
Slammed70's Avatar
Thanks,
Buddy
Yes, indeed you could. Any SBC/90 degree V6 will interchange.
After all, a 4.3 is a 350 with two holes missin.
Infact my neighbor uses SBC 6in rods and .040 over pistons in his Syclone.
Old 12-22-2006, 03:16 AM   #16
sixty8c10
sixty8c10's Avatar
It sounds simple enough, I am doing enough mods to my truck right now that alot of the little stuff like fuel lines, a/c lines will be easy.
