Old 12-21-2006, 03:33 PM   #1
1969k10stepside
Arrow Inspecting axles
While I am painting my axles on my swb K10 I will have them out of the truck and I was wondering what I should look for on the dana 44's.The truck has never been drove while I have owned it and I never seen it moved except when I pull it with the 4 wheeler from garage to the shop to work on.It didnt have the lockouts installed on the front axle when I got it.So what should I look for on these axles that could possibly be damaged or worn out?Any certain areas to check?Several wheel studs are broke off,where can I get replacements and what is involved in changing them?
1969k10stepside is offline   Reply With Quote
Old 12-23-2006, 05:47 PM   #2
1969k10stepside
Re: Inspecting axles
Finally got around to taking the covers off.Luckily there was no metal shavings in the oil.Now I just have to figure out what gear ratio it is.
Old 12-24-2006, 07:10 PM   #3
1969 GMC
1969 GMC's Avatar
i'd just check for the obvious, since you said it didnt have hubs inspect the wheel bearings, and maybe look at the ball joints too.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-24-2006, 07:46 PM   #4
msgross
msgross's Avatar
should be some numbers on the ring gear...I would guess 3.08's
msgross is offline   Reply With Quote
Old 12-24-2006, 09:48 PM   #5
1969k10stepside
I wouldnt think it would have 3:08's on it being a granny 4 speed but who knows.I will figure it out when I rebuild them.
Old 12-25-2006, 12:03 AM   #6
msgross
msgross's Avatar
I can't confirm but have been told that my 68 has them. It has a granny gear as well. No other gearing listed on the glove box either.
