Old 12-21-2006, 10:18 PM   #1
FormerMember
I have a "New" project:
A 1970 (small rear window) C50 Wrecker.
Pics will be coming soon.
The plan:
Make it four wheel drive. I have an SM465, 203/205 doubler combo for it. I will also install a set of 2.5ton Rockwells under it...
FormerMember is offline   Reply With Quote
Old 12-21-2006, 10:40 PM   #2
bowtiehotrodder
SIX BANGER
bowtiehotrodder's Avatar
Re: I have a "New" project:
you know we NEED PIC> NOW we will go thru withdraws with out them nnnnnooowww thanks good project
http://www.cardomain.com/ride/2597018(NN)
1979 chevy truck swb 454 w turbo400 with buckets
1977 chevy truck swb soon to be 454
1976 chevy dually 454
1969 chevy truck six shooter
bowtiehotrodder is offline   Reply With Quote
Old 12-21-2006, 11:30 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Sounds like a cool project! (BTW all conventional C40-C90?'s had small back windows, I used to drive a '70 C/50 grain truck and it also had a small back window, not sure why GM did that)
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 12-21-2006, 11:56 PM   #4
krue
Designated A-hole!
krue's Avatar
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-21-2006, 11:59 PM   #5
1969k10stepside
1969k10stepside is offline   Reply With Quote
Old 12-22-2006, 12:42 AM   #6
FormerMember
Ok, so maybe it's not a 67. It was listed as a 70, but when I saw it, I thought 67.
I will probably be swapping a C10 cab onto it, as this one's rusted.
Old 12-22-2006, 06:22 AM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
Here is mine........GMC 5500. Ive been plaing with it for a few years. Its about done except for paint and body
72freak is offline   Reply With Quote
Old 12-22-2006, 10:27 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Originally Posted by grendel View Post
Make it four wheel drive. I have an NV4500, 203/205 doubler combo for it. I will also install a set of 2.5ton Rockwells under it...
You know of course you have me drooling with thoughts of that truck as a finished product
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-22-2006, 10:36 AM   #9
FormerMember
The only problem that I have with the axle combo is weight handling.
I am thinking 5 tons may have to do it.
The C50 is a five ton truck, right? GCVW on this is from 15K to 26,500.
If I went with the 5 ton axles from a mil spec truck, that would be 20K. Still not enough to hit the top GCVW.
Old 12-22-2006, 10:36 AM   #10
CUSTOM/10
CUSTOM/10's Avatar
Guess I'll have to stop by and see this beast, once I get my Christmas shopping done. Maybe we can put this cab on it !!!
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-22-2006, 10:43 AM   #11
FormerMember
I am around all day... heck, unless you're taking the yellow one it may go on this!
The wrecker bed's going to be sandblasted, repaired and powder coated.
Jim brought back a HUGE powdercoating oven for a gent over in Merrimack who still apparently owes him a bit...
Old 12-22-2006, 10:51 AM   #12
CUSTOM/10
CUSTOM/10's Avatar
I'm kinda liken the yellow one.
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-22-2006, 10:59 AM   #13
FormerMember
Heh, gee, I wonder why?
Sell off your other one then. The Yellow's yours.
You may have to help with cab corners and rockers on one of these...
Old 12-22-2006, 11:08 AM   #14
CUSTOM/10
CUSTOM/10's Avatar
Might stop by IF they let us out early. Have to go to Salem then swing by if it's not too late. The one in the pic dosen't need much, just a little TLC.
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-22-2006, 12:16 PM   #15
FormerMember
Pics:
Sorry for the trees where she sits... it's a bit tough to move this sucker around, without it running.
Stats:
Tired worn out 292 (I assume) I-6
Some sort of 5 speed transmission
HUGE rear axle
dry rotted tires
a ton of bondo
and 15-20 layers of peeling paint over rust.
The plan:
free flowing 350 or a 427 Tall deck.
Might fix this cab, might swap on the one seen above.
keep it pretty low, but run a 46" Michelin Mil Tire on 20" rims.
disk brakes in the front, pinion brakes with drums on the rear. Should stop on a dime!
Old 12-22-2006, 01:22 PM   #16
jerry moss
Born Psycho
jerry moss's Avatar
Thumbs up Re: I have a "New" project:
around here the phone company and pacific gas & electric both use all wheel drive BIG trucks for boom trucks and cable stretchers. theres a f*&d f-700? in a local wrecking yard with some gnarly all wheel drive axles, huge transfer case and transmission still in it. both companies also use G.M. trucks that are real monsters, they sit so tall that the headlights are in the bumper--i assume to meet calif's headlight height laws. if you could pick one up at auction for the right price, you would have a matched set of HEAVY DUTY running gear components.
looks like a fun project, please post more pics as you make progress.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 12-23-2006, 04:57 AM   #17
72LoBurb
Yup, I'm comp-useless
Do you know if that was a manufactured(ie Holmes, Century) towing deck or a homemade unit? Some specs on the towing deck would be interesting, to me anyways.
72LoBurb is offline   Reply With Quote
Old 12-23-2006, 10:19 AM   #18
FormerMember
It's a Holmes 660
Old 12-23-2006, 07:46 PM   #19
72armyswbtruck
72armyswbtruck's Avatar
What a magnificent Beast
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 12-23-2006, 08:49 PM   #20
Judging by the front sidemarkers on the fenders and the newer style cab lights that would be a '70, very cool! That 5 speed is probably a Spicer, Clark, or a New Process. Is that a hi-lo axle or a single speed?
RJD
Old 12-23-2006, 08:52 PM   #21
FormerMember
It's a 2 speed rear axle (hi-lo).
I haven't looked, but it's probably a Clark. I may try adapting a t-case to the butt end of it.
Old 12-23-2006, 08:56 PM   #22
1969k10stepside
Now that I have seen pics I can say that truck will be huge.You have your work cut out for you.Cant wait till I see some pics of it up in the air
Old 12-23-2006, 09:10 PM   #23
FormerMember
Actually, size won't increase too much. Those tires on there are pretty large. I am guessing about 36" tall.
Old 12-23-2006, 09:13 PM   #24
1969k10stepside
Guess you need some 44's or bigger then
Old 12-23-2006, 09:16 PM   #25
earl87gta
earl87gta's Avatar
That thing is way cool I think I would have to put a 5.9 diesel in it with all the power add ons.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
