Old 12-29-2006, 10:57 AM   #1
tallhoedude
ROCKWELL 5 TON CLUB !!
tallhoedude's Avatar
14 Bolt Drw To Srw?
Anyone Know What Is Involved In Swapping A Rear 14bolt Axle From Drw To Srw?ill Be Going To Disc Brakes If That Matters?
1970 K5 "ON THE ROCKS" PROJECT:500hp 6.0 fuel injected. 2wd sm465 trans,t136 2.5 ton transfercase,5ton rockwells with 9.34 gears,custom wheel disc brakes,full hydro steering20+" OF LIFT AND 67/35/25's..67" tall TRACTOR TIRES.."THE MUD SLUT!!"
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=221935
1997 TAHOE,SAS D60 14B,5:13 DISC BRAKES,CROSSOVER STEER,HYDRO ASSIST,42 IROKS
HINT:NEW NAME "K5ontheROCKS!"
tallhoedude is offline   Reply With Quote
Old 12-29-2006, 11:08 AM   #2
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: 14 Bolt Drw To Srw?
i cant remember if the spindle itself is longer but the backing plates are closer to the ceter of the axle so you will need to custom fab something to hold the caliper mount. it also has the perches in closer too so moving them should be needed, unless your are keeping it in the truck that its in.
trkklr77 is offline   Reply With Quote
Old 12-30-2006, 10:55 PM   #3
Americanrider
IIRC thereare Two types of DWR axles, the narrow C&C and the full width. Which do you have?
Americanrider is offline   Reply With Quote
Old 12-31-2006, 12:26 AM   #4
cobinder
Everything is work in progress
cobinder's Avatar
tall I went the other way. If your drw is off a chassis & cab truck it's a simple swapping the type B hubs for the standard type A hubs. Inner axles and bearings all swap just fine ( it least mine did). The disc brake bolt up can be done, it just takes a spacer outboard of the mounting flange on the axle. Randy @ http://www.blackbirdscustomtrucks.com can set you up.
I have a pair of what your after sitting on a shelf. The one on the right is the type B drw the other is the type A your after.
cobinder is offline   Reply With Quote
Old 01-04-2007, 11:59 AM   #5
1969K10
1969K10's Avatar
tall - PM sent
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
