Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-30-2006, 02:07 AM   #1
poorboy
poorboy's Avatar
Best tool in the shop
I can relate to most of these.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal
bar stock out of your hands so that it smacks you in the chest and
flings
your beer across the room, splattering it against that freshly painted
airplane part you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the
workbench with the speed of light. Also removes fingerprint whorls and
hard-earned guitar calluses in about the time it takes you to say,
"Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes
until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion,
and the more you attempt to influence its course, the more dismal your
future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is
available, they
can also be used to transfer intense welding heat to the palm of your
hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable
objects in your shop on fire. Also handy for igniting the grease
inside the
wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2
socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after
you have installed your new disk brake pads, trapping the jack handle
firmly
under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile
upward off
a hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbors to see if he has another
hydraulic
floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog**** off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any
known
drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on
everything
you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably
has an
accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called
a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which
is not otherwise found under cars at night. Health benefits aside,
it's main
purpose is to consume 40-watt light bulbs at about the same rate that
105-mm
howitzer shells might be used during, say, the first few hours of the
Battle
of the Bulge. More often dark than light, its name is somewhat
misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your ****; but can also be
used,
as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power
plant 200 miles away and transforms it into compressed air that
travels by
hose to a Chicago Pneumatic impact wrench that grips rusty bolts last
over
tightened 58 years ago by someone at ERCO, and neatly rounds off their
heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket
you needed to remove in order to replace a 50¢ part.
HOSE CUTTER: A tool used to cut hoses too ****.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used
as a kind of divining rod to locate the most expensive parts not far
from
the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard
cartons delivered to your front door; works particularly well on
contents
such as seats, vinyl records, liquids in plastic bottles, collector
magazines, refund checks, and rubber or plastic parts.
dangit TOOL: Any handy tool that you grab and throw across the garage
while yelling “dangit” at the top of your lungs. It is also the next
tool that you will need.
poorboy is offline   Reply With Quote
Old 12-30-2006, 05:12 AM   #2
desertrat
desertrat's Avatar
Re: Best tool in the shop
all so true!
desertrat is offline   Reply With Quote
Old 12-30-2006, 05:25 AM   #3
ghetto_superman
ghetto_superman's Avatar
everything
BAHAHAHAHHAHA!!
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 12-30-2006, 07:36 AM   #4
krue
Designated A-hole!
krue's Avatar
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 12-30-2006, 09:32 AM   #5
Yep, I have most all of those
Old 12-30-2006, 10:29 AM   #6
truckdude239
truckdude239's Avatar
after
firmly
under the bumper.
upward off
TWEEZERS: A tool for removing wood splinters. from above mentioned Eight-Foot long Douglas Fir 2x4 that was use to lever the automobile off the above mentioned hydraulic jack handle, which results in having the splinter deep in your hand.
sorry i had to edit it lol
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is online now   Reply With Quote
Old 12-30-2006, 11:05 AM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
LOL, thats a pretty good list!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 12-30-2006, 11:54 AM   #8
49studebaker
49studebaker's Avatar
That's too funny, people that don't do what we do for hobbies would never understand! But most every tool you've discribed, we can relate to.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 12-30-2006, 02:43 PM   #9
Bandit76
Bandit76's Avatar
Those are good. Fear and common sense usually put shop safety to the test.
2011 Chev Silverado LT 1500 4x4 Crew Cab 5.3l
2005 Toyota 4Runner family beater
...would have more but my yard ain't all that big...
..nothing like a Chevy fence all bought and paid for..
...there's a few holes in it though...
Bandit76 is offline   Reply With Quote
Old 12-30-2006, 03:37 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Great list -- and it must be from Peter Egan!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 12-31-2006, 12:27 AM   #11
boraxman
Keepin an eye out
boraxman's Avatar
Lets not forget the all-mighty air impact wrench!
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 12-31-2006, 01:03 AM   #12
7387chevys
known
Thus why I have an Edelbrock Intake.......thermostat bolts in stock intake ....snap snap..........drillll.....ez out snap.......
Shane
7387chevys is offline   Reply With Quote
