Parting hot rod 72 Cheyenne
Well, I can't seem to sell my 72 so I'm parting it out. I'm not taking anything off until the motor sells. After that everything is fair game. I want $4000 for the motor. It has about 2000 miles if that since it was rebuilt. I have all reciepts. You can hear and drive if you want to. after the motor sells I'll price the rest of the truck parts. This is just for the motor at this time. I'll ship it but buyer will have to pay for it.
1972 Chevy Cheyenne Motor:454 .60 468 ci cast crank turned .10 .10 Shot-peened rods with ARP bolts Speed-Pro coated pistons Comp Cams 282 solid cam with Comp Cams lifters and pushrods Lunati roller thrust bushing Cloyes double roller timing chain Mini starter TCI flexplate with ARP bolts Oval port heads with hardened seats, 3 angle valve job Manley valves 2.19 and 1.88 Crane Gold roller rockers 7/16 stud Edelbrock Airgap intake Moroso Billet valve covers Full MSD ignition with 6AL box Taylor wires Demon carb Transmission: TH350 Full manual conversion B M Holeshot 3000 converter B M Megashifter B M 24,000 GVW cooler TCI line lock 1 piece driveshaft with new yoke and Spicer Ujoints Exhaust Headman coated headers 1 7/8 tube 1 chamber Flowmaster mufflers 3 inch pipe with"H" pipe and dumps in front of axle Rearend 12 bolt Richmond posi 4 series carrier 4:10 gears M/W axles Fuel system Holley fuel pump Holley regulator RCI fuel cell under bed Fram filter Goodyear Hose Braided from regulator to carb Cut-off switch for pump mounted into back-up light Suspension and brakes: 4 wheel disc with CPP rear disc kit 1972 Corvette master cylinder, new booster Master power prop valve Stainless hose upgrade New Emergency brake cables Fresh brakes up front 5 lug factory disc DJM 3 inch drop front springs Chisholm spindles Chisholm upper tubular control arms 1 ton front sway bar Rear DJM 6 inch drop springs Brother adjustable tracking arm Rebuilt front suspension Wheels and tires 15X10 rear Centerline Telstars with ET Streets 15X7 front with 245/60 tires Misc New 4 core radiator New carpet and kick panel carpet recovered seat New gauge panel AutoMeter gauges with Playback tach and shiftlight Kenwood CD with electric antenna mounted in stake pocket New cab mounts Spray in bedliner New wiring Battery relocated to bed Sir Michaels steel roll pan in rear |
Re: Parting hot rod 72 Cheyenne
How much do you want for the 12 bolt posi rear end?
Commander Taco Bello
hate to see a truck like that get parted out...
very nice ride you have there. |
Thanks! I hate to part it out but I can't seem to sell it. I have reciepts for just under 20K and it wont sell for 10K. I can part it and get more than the 10K so I guess it will be parted out. I found something else I want and need the cash to get it before it sells.
#5 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
![]() Join Date: Nov 2005
Too nice to part out , can you send me ( or post ) some pix pls .
Thanks ...................................... Doug
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
Very Nice truck hate to see her parted out. Really wish I had the money. Do you take payments...........lol............
Here is a link to Ratrod's original post http://www.67-72chevytrucks.com/vboa...d.php?t=218289
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 |
very nice parts,but what the heck does the truck look like, that you cant sell it for that kind of money every thing looks good
Here's his other post you guys, isn't this the truck?
http://67-72chevytrucks.com/vboard/s...d.php?t=218289 |
Sweet Truck........sorry you hav eto part it............
Active Member
Holy hell, I can't believe you're not able to sell that for $10k. That's a gorgeous truck. Somebody needs to buy that so it doesn't get parted out. What a shame that would be. If only I wasn't in school right now, I'd drop $10k on that in a heartbeat.
#12 | |
#13 |
Active Member
http://www.oldchevytruck.com/chevytrucksforsale/
If you can not sell your truck on this site list it on the link above. I had my 454SS for sale several places waited 8 weeks had some calls but nothing great, listed it on Old Chevy Truck and my email lit up. The buyer flew in from New Mexico and bought the truck. Good Luck!!!!
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
#14 |
![]() Join Date: Feb 2004
Damn, that is a super nice truck
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
#15 |
don't part it out...........too nice
#16 |
how much for the wheels? if you part it
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
#17 |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
How much for the auto trans x-member, the bracket from the firewall to booster?
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
#18 |
I would trade my truck and my bike to see that not get parted.
#19 |
The Best Member
Dont Part A Perfectly Good Truck!!!!!! Keep Them On The Road!
70 shortbed C10 -------SOLD------- 1972 Chevy C-10 l/b |
#20 |
![]() Join Date: Aug 2005
Wish I had $10K
#21 |
Bump up again.
#22 |
Chevy's Rock!
![]() Join Date: Apr 2004
Nice Truck! <bump>
John '59 NAPCO Pickup '70 K10 Pickup 350 '72 C20 Suburban 350 (MIA) '57 Chieftain 455 '68 Firebird Convertible - 400 '68 Catalina Convertible - 400 '85 Vette |
#23 |
Chevy truck addict
If you part it what you want for the hole trans set up, i was gonna do all of that to mine but if you part it im interested.
ransmission: TH350 Full manual conversion B M Holeshot 3000 converter B M Megashifter B M 24,000 GVW cooler TCI line lock 1 piece driveshaft with new yoke and Spicer Ujoints Last edited by AesC10s; 01-10-2007 at 01:23 PM. |
#24 |
Beautiful truck, it will be a shame to see that thing get cut up, taken apart and spread all over the place.
Soon to be selling all but one, or two... Depends on what the Boss has to say....... 67 GMC Shortbed 454 Project more junk and most of it is for sale |
#25 |
Who me?
4 wheel disc with CPP rear disc kit 1972 Corvette master cylinder, new booster Master power prop valve Stainless hose upgrade New Emergency brake cables Fresh brakes up front 5 lug factory disc DJM 3 inch drop front springs Chisholm spindles Chisholm upper tubular control arms 1 ton front sway bar Rear DJM 6 inch drop springs Brother adjustable tracking arm Rebuilt front suspension Put me in line for these parts when you decide to sell, let me know Thanks for your time, Brian
Living the dream ![]() 72 2WD Blazer, under going porter built surgery 67 GT Mustang fastback 67 Mustang coupe C/S clone 64 Falcon sprint hardtop |
