Old 01-06-2007, 08:28 PM   #1
Rally Nova
Rally Nova's Avatar
'69 GMC shift lever swap
How hard is changing out the automatic shift lever on the column on '69 GMC?
Can it be done without tearing the steering column apart? I bought a new one from GMCPaul's, because my original is rusty. TIA, David
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
2004 GMC 2500 Crew Cab
Rally Nova is offline   Reply With Quote
Old 01-06-2007, 08:35 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: '69 GMC shift lever swap
quite easy.
The steps depend one one thing though... is this a tilt, or a straight column?
Old 01-06-2007, 08:38 PM   #3
Rally Nova
Rally Nova's Avatar
It's a regular ol' straight column!
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
Old 01-06-2007, 08:57 PM   #4
Longhorn Man
if I remember right... and some one correct me if I am wrong... pop the pin that holds the lever in there, wiggle it a bit, and slip the new one in and replace the pin. It's been 5 or 6 years since I have messed with the straight column... so lets get another opinion on it... but I think it's a simple R&R... no shifter spring like the newer ones or the tilt.
Old 01-06-2007, 09:15 PM   #5
fine69
fine69's Avatar
True, simple as Andy tells it.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 01-06-2007, 09:45 PM   #6
Longhorn Man
thanks mike...I was pretty sure of it.
Old 01-06-2007, 10:59 PM   #7
Rally Nova
Rally Nova's Avatar
Thanks Guys for the quick info!! Finally something simple & straightforward. I'll probably change it out on Monday, my only day off till Friday!
1969 GMC C-1500
1972 Rally Nova
1988 Monte Carlo SS
Old 01-06-2007, 11:06 PM   #8
fine69
fine69's Avatar
Why wait? It only takes about 5 minutes. Think of how much better you will feel knowing you accomplished something.
Board member #6
Old 01-06-2007, 11:08 PM   #9
Longhorn Man
yeah, then monday you can do what you really wanna do.... nothing!
