01-08-2007, 12:19 AM | #1 |
Car Truck Bike Nut
Lowered my 68 the quick way
I'm planning a suspension swap some year with a 72 parts truck I have, so a buddy torched my springs and lowered my driver 68, does ride a little bouncy but not too bad, he says shave my bump stops to take some of that away. One before pic, the rest after
Snow free Florida panhandle, don't miss Indiana winters Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL 68 shortfleet project 94 3500 TD dually so many cars so little time 72 K2 CST 2WD Blazer |
01-08-2007, 12:20 AM | #2 |
Re: Lowered my 68 the quick way
lowered nicely... since your dropping the old school way, couldn't you also cut some coils?
Not Sponsored By Mommy And Daddy Kustoms |
01-08-2007, 12:28 AM | #3 |
yep cutting coils works, but be carefull not to cut too much off....
01-08-2007, 12:43 AM | #4 |
THE VILLIAGE IDIOT
looks good..you chevy guys got it so easy when it comes to dropping...this why im gonna get a rear end set up out of a chevy..
honestly honey,,i have no idea how that truck got here. |
01-09-2007, 02:54 PM | #5 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-08-2007, 12:58 AM | #6 |
Happy to be here
I hope they don't cause a fatal accident when they collapse.
01-08-2007, 05:42 AM | #7 |
its all about the +6 inches
you can't really cut coils out of the rear, they are pigtailed.
I've lowered more cars/trucks than I can remember, all with fire, and never had a single one shatter, crack, split,etc. And these were all for teenagers that drove like crazy. Can it happen? I'm sure it has once or twice. Does he have anything to worryabout? Naaaaaa. |
01-08-2007, 07:07 AM | #8 |
Unskilled Labor
So when can I bring my truck over?
1986 K/20, 350/TH400, My First 4x4....... |
01-09-2007, 02:54 PM | #9 |
Questionable
Or three times. Here is one from the Mercedes a friend here in town drives - you take a risk any time you improperly lower a vehicle - I think it shows a gross disrespect for other people on the road to hack your suspension to save $90 on a set of lowering springs, especially when stuff like this can happen. Only thing that saved him was the spring got lodged in itself, lest shock would have bottomed out/exploded and who knows what would have happened:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 01-09-2007 at 02:55 PM. |
01-09-2007, 03:44 PM | #10 | |
In Memoriam...
Torching springs will get it lowered, but you are... 1...taking a big risk to save a few $ 2...risk lowering it unequally all sides, resulting in a silly lookin' truck, which can only be fixed by...new springs. 55chevy...I'm not trying to slam you or your truck. I'm just offering MY opinion on this topic since it was brought up in prior post. The heat will cause the spring to become brittle. Spring coil stock has different properties than other types of steel on the truck. Tempering springs by heating them is NOT a good idea. Even if the springs are cut with a cut-off wheel, it is recommended that the spring is kept wet to minimize the tempering. Just my $ 0.02.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
01-08-2007, 07:00 AM | #11 |
Your buddy does nice torch work
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
01-08-2007, 07:33 AM | #12 |
THE VILLIAGE IDIOT
ok when i went to bed last night i was thining about lowering my truck,,and rembered a old toyota ipickup i slamed,,by putting the rear axle on top of the leaf springs, plus 4 or 4 in blocks...wouldnt that work with my gmc to,,then i could just heat or cut the front ones...but since i have never used heat,,im not sure how to do it,,or is it netter to cut it..
01-09-2007, 02:46 PM | #13 | |
Car Truck Bike Nut
Lowering blocks should work, altho I've never used them on leaf springs. Cutting coil is preferable over torching, just more labor involved. Took buddy a while, he says 6 cylinders don't come down as quick as an eight, I had to sit on the truck to add some fata$$. |
01-09-2007, 02:53 PM | #14 |
THE VILLIAGE IDIOT
the only springs i have cut,,i was installing on a mark 7 i used to own,, converted it to coils when the factory air ride went out...after spending all day fighting them to get the front ones in,,a friend came over and asked why i didnt just cut them..well after feeeling stupid i ran them up and cut them,,darned if they didnt go right in and gave me a good stance to boot.. how many should i cut out for say a 3 inch drop on the front,,maybe even 4...
01-09-2007, 07:31 PM | #15 |
I did that on a 69 el camino I had a long time ago. It worked fine but I dont think Id do it again...
01-09-2007, 09:11 PM | #16 |
The LuvShack Garage
I have had 2 rigs lowered this way, never again, but that's due to the ride
quality. The Black one was driven for almost 8 years as a DD and sold after 10 years of hard driving, the Gray one was used only 3 years, never had a issue on either of them w/ the coils, however Ball joints are another story
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
