01-14-2007, 07:35 PM | #1 |
Sierra Grande Club
Woodruff key fell into the oil pan….
I was replacing the timing chain and the woodruff key fell in the oil pan. I don’t think it can hurt anything but thought I better get a second opinion.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-14-2007, 07:36 PM | #2 |
Re: Woodruff key fell into the oil pan….
It can't go anywhere. It will just sit on the bottom. I wouldn't worry about it.
01-14-2007, 07:39 PM | #3 |
for the price of a pan gasket i'd drop the pan and remove it
01-14-2007, 07:44 PM | #4 |
Broken Down
You can probabbly get away with leaving it but why roll the dice? a one piece gasket is less than 40$$. Did you try a magnetic retriever?? Just my .02
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
01-14-2007, 07:49 PM | #5 |
Sierra Grande Club
What I would like to do is get it together and drive (25 miles) so I can rent a lift and drop the pan and inspect and reseal the oil pan.
s/t
01-14-2007, 07:51 PM | #6 |
Sierra Grande Club
Another question, is the woodruff key the same size as the harmonic balancer’s? I was going to size it before it fell.
s/t
01-14-2007, 08:00 PM | #7 |
Broken Down
I think the balancer's is longer.
01-14-2007, 08:08 PM | #8 |
I'd try fishing for it with a magnet, either through the drain plug hole or the opening between the front of the pan and the front crank bearing cap. I have a magnet on a stick, but it's not the telescoping kind. It's the flexible aluminim stick about 18" long that can be bent into the perfect shape. Magnet's about 1/4" in diameter. Shaft it's on is about 1/8" to 3/16" diameter and seems like the ideal tool for the job.
Good luck.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 01-14-2007 at 08:09 PM. |
01-14-2007, 08:32 PM | #9 |
Sierra Grande Club
I tried to fish it out but it has slid to the bottom of the pan. I don’t think there is any danger of it getting into anything, it’s just a PITA.
The key slots appear to be the same I’ll get the calipers and check the depth & length of each slot. My harmonic balancer came with two keys too. I think I’m good now. s/t
01-14-2007, 08:34 PM | #10 |
Junior Member
When I pulled a 305 apart (was in my camaro when I bought it), I found a few pieces of aluminum - took me a few minutes, but I eventually realized they were pieces of pistons skirts. Turns out the outside tang of each piston on the drivers side broke off like this. I can only assume the engine saw some high rpms - never heard of this happening before. Anyway, they were too big to get into anything, and didn't seem to have hurt anything.
I agree with mnunn454 though. If it's steel, then you can use a magnet to get it out. If the engine's in the truck, and you already have the timing cover off, it'd be easier (I suspect) to use the magnet on a stick idea (I've got a couple of the telescoping kind, so that's what came to mind).
69 GMC Sierra 1500 Custom 68 Camaro SS 18 GMC Sierra SLT Living the dream |
01-14-2007, 09:13 PM | #11 |
A-Adam A-Adam
I wouldn't worry about it. It is heavy. It will stay on the bottom of pan. It can't be suck in to the oil pump.
70 3/4 ton GMC Camper Special |
01-14-2007, 09:14 PM | #12 |
Cantankerous Geezer
I can't remember the size, but the parts store should be able to tell you. And I wouldn't even try fishing for the key, it will sit at the bottom of the pan forever. When I pulled the pan on one engine, I found a handful of screws. I assume they were there when I bought the van, about 80,000 miles earlier.
Fred There is no such thing as too much cam...just not enough engine. |
01-14-2007, 09:44 PM | #13 |
Drain the oil ... take a STRONG magnet and start "wiping" the oil pan with it ... side to side, working your way back to the oil plug ... do this a few times and the Woodruff key should slide with the magnet on the inside of the oil pan.
Good Luck. |
01-14-2007, 09:46 PM | #14 |
Sierra Grande Club
Good then it should be safe for the drive to the lift.
Anyone have the torque spec for the timing gear bolts? thanks everyone. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 01-14-2007 at 09:47 PM. |
01-14-2007, 09:49 PM | #15 |
I would replace the drain plug with one with a magnet. Then maybe you'll get lucky and it will get stuck on it.
01-14-2007, 09:53 PM | #16 |
The camshaft sprocket bolts (5/16) are 20 ft. lbs.
01-14-2007, 09:56 PM | #17 |
Sierra Grande Club
cool! Thank you. BTW I like the magnet drain plug idea too.
01-14-2007, 10:03 PM | #18 |
A-Adam A-Adam
I Like the last two Magnet ideas!
01-14-2007, 10:14 PM | #19 | |
A Speaker magnet would probably do the trick, provided you have an old speaker laying around.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
01-14-2007, 11:09 PM | #20 |
Sierra Grande Club
BTW- the woodruff key isthe same on the timing sprocket & harmonic balancer.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 01-14-2007 at 11:11 PM. |
01-14-2007, 11:14 PM | #21 |
USE LOCKTIGHT ON THE CAM GEAR BOLTS..if you not using a lock plate
01-14-2007, 11:22 PM | #22 |
01-14-2007, 11:27 PM | #23 | |
Sierra Grande Club
Thanks for checking! s/t
