Old 04-24-2002, 05:07 PM   #1
Sams 68
Post Sticky Rear Drum Brakes
This makes Two trucks in a row that I have had trouble with the drivers side rear brake dragging. Any one else??? Any suggestions would be Great!!! Thanks Sams 68
Sams 68 is offline   Reply With Quote
Old 04-24-2002, 06:07 PM   #2
bigvinnie
bigvinnie's Avatar
Post
could be build-up of gunk in your wheel cylinder preventing the cup/plunger from returning after you apply the brakes. Could also be weak brake shoe return springs...
I'd replace the wheel cylinder and put in a new brake spring kit... might as well do both sides so they're both fresh, can't hurt...
could also be improperly adjusted e-brake cable as well....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
http://www.ixpres.com/vlusardi/chevtrk.htm
[This message has been edited by bigvinnie (edited April 24, 2002).]
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 04-25-2002, 06:48 AM   #3
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Arrow
Join the club!
My '69 definetly wears the driver side more than the other side and I used to have problems with it locking up after a nice ride. I have replaced parking brake cables, even replace the driver side twice. I put in new springs twice. I too am at a loss as to what's causing this. Last year I had to swap my brake shoes side to side to get some decent mileage out of them.
I used to have a '69 4X4 Blazer that did the same thing.
If you raise the tire off the ground, the brakes feel free. ????????????????????
63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle
Parts for sale:
http://www.angelfire.com/trek/mr409/items4sale.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 04-25-2002, 08:45 AM   #4
BubbaGreen
Post
check the little 'star' adjustment wheel,
if the teeth are worn, it will over adjust
make the lines wear. the thing is at the
bottom between the shoes.
71 Chevy C-10 SWB Fleetside WAS:307w/3-on-the-tree NOW:350TBI/700R4/3.73
See it at www.prismnet.com/~grzanich
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
BubbaGreen is offline   Reply With Quote
Old 04-25-2002, 10:05 AM   #5
1-PU70
1-PU70's Avatar
Post
I think if the teeth on the star adjuster were worn that would cause the shoes to back off. I would say that eather they are over adjusted or you have groves in the backing plate where the shoes ride
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
