Old 02-01-2007, 01:48 AM   #1
TDogg490
Compressor Questions
I was looking for a simple air ride setup for my 67 LWB... but my main concern is the compressor... ive heard trucks with compressors and they're extremely loud! does anyone have a compressor they recommend thats quiet(er?) i dont need extreme psi... 150 is enough. any suggestions would be awesome
TDogg490 is offline   Reply With Quote
Old 02-01-2007, 02:22 PM   #2
XXL
Seņor Member
XXL's Avatar
Re: Compressor Questions
As far as air compressors go, 150 is pretty close to "extreme"... you won't likely find one that does less than that. As for noise, they're all pretty noisy {tiny, cheap piston and "bearings" being spun like a top}, but you can mitigate some of that noise using isolation mounting techniques. If it's the sound in the cab that bothers you, try mounting to the rear of the vehicle. Don't mount underhood. Noise there seems to translate into the firewall, which means you'll get it in the cab.
XXL is offline   Reply With Quote
Old 02-01-2007, 02:22 PM   #3
71swb4x4
71swb4x4's Avatar
If engine driven is an option then a York might work for you.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 02-01-2007, 02:27 PM   #4
jimmydean
jimmydean's Avatar
My Thomas is loud when you're next to it, but with the engine running, I can barely hear it. I have it mounted on the passenger side of the frame all the way in the back.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-01-2007, 03:54 PM   #5
1lowdiesel
1lowdiesel's Avatar
air zenith or viair 450. but engine driven would be your best bet. i've got a buddy thats got a few of em' if your interested
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 02-01-2007, 04:50 PM   #6
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Thomas 337s are about the quietest Ive heard.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 02-03-2007, 01:19 AM   #7
CHAPS7931
CHAPS7931's Avatar
york on my truck and its so quiet and i have it set for 200 psi. best comp. i ever used and the psi is great for super fast filling time compared to viar and thomas put together
CHAPS7931 is offline   Reply With Quote
Old 02-03-2007, 06:41 PM   #8
SlammedDime
SlammedDime's Avatar
I'd go with a Viair 420 on a 3-5 gallon tank. The 420/460/480 are quieter than their predecessors, and the 420 is faster than the 450/460, and since you don't need 200 psi, i wouldn't bother with the extra cost of a 480.
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
