Old 02-02-2007, 10:52 AM   #1
jlaird
jlaird's Avatar
panhard location
I know a panhard bar should be level at ride height, but should it be installed so it's parallel to the axle? If not, what should the max angle (to axle)?
Thanks,
Josh
jlaird is offline   Reply With Quote
Old 02-02-2007, 11:18 AM   #2
jimmydean
jimmydean's Avatar
Re: panhard location
I don't think it's supposed to be level. I don't think mine is even level at full dump.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-02-2007, 01:09 PM   #3
Tony@AirRideTech
Junior Member
Ideally you want it as level to the ground and parallel with the axle as possible at ride height. This is where you will see the least amount of lateral movement.
Tony@AirRideTech is offline   Reply With Quote
Old 02-02-2007, 01:29 PM   #4
jlaird
jlaird's Avatar
perfect! That's what I needed to know. Really wanted the watts link, but I think i'm going to save the money for other parts.
Old 02-02-2007, 01:43 PM   #5
Tony@AirRideTech
Junior Member
There is absolutely nothing wrong with a properly set up panhard bar. Lateral movement is minimal through an average range of travel.
Old 02-02-2007, 02:04 PM   #6
jlaird
jlaird's Avatar
that's good to know. Watts links are just KOOL!
Old 02-02-2007, 03:05 PM   #7
Tony@AirRideTech
Junior Member
Watts links are definitely cool and they work awesome when set up correctly... they also give you more points for failure too.......
Old 02-02-2007, 04:35 PM   #8
jlaird
jlaird's Avatar
That's true too.
